Balancing Trailer Tires
/ Balancing Trailer Tires #1
firefighter jim
I've always balanced my trailer tires. Thought it was a good idea just as balancing vehicle tires. Increased tire life and smoother riding trailer with a load or without a load. Recently in a tire job and was surprised to hear that most people do not. Any comments appreciated...........
/ Balancing Trailer Tires #2
All tires should be balanced. If someone tells you your trailers tires do not need balanced move on because they have no idea what they are talking about.
Chris
/ Balancing Trailer Tires #3
For years I never balanced them and didn't know any different. Then I bought an old bubble balacer at an auction and figured what the heck. The difference was beyond description. All the road vibration was gone and the mnii-wobble at 45 MPH was not even there at much higher speeds. One of the best things I have ever done.
/ Balancing Trailer Tires #4
I also balance all of my trailer tires. It's cheap and makes a noticeable difference when hauling empty or light loads. According to my local tire store, almost no one balances them. Not sure why.....
/ Balancing Trailer Tires #5
I never had the tires that originally came on my tandem trailer rotated or balanced. When it was time to get a new set I got radials and get them rotated and balanced once a year.
I'll double the life of them compared to the cheap tires that came on the trailer.
/ Balancing Trailer Tires #6
I've always done it. Even with the commerical trailers I service at the shop. Heck I even done it on my motorcycle trailer.
/ Balancing Trailer Tires #7
ignorance = unbalanced trailer tires
One of the difficulties I've encountered was hub or lug centric. Only a very few tire shops will balance a tire based on the lugs..
I figure any balance correction is better than none.
(1) UNUSED 9.5-16 TIE W/ 6 LUG RIM (A64280)
(1) UNUSED 9.5-16...
UNUSED AGT ATK-B1000 TWO-POST CAR LIFT (A64281)
UNUSED AGT...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
2014 Hagie DTS10 Sprayer (A63111)
2014 Hagie DTS10...
2017 Case CX145D (A60462)
2017 Case CX145D...
UNUSED WOLVERINE 44" HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
