Bagger Install
/ Bagger Install #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
I got the bagger attachment for my BX2200 w/60in. deck and since I have the Pats Easy Change on the lift arms, I found that I cannot attach the bagger unless I remove the PEC or make some changes. I will show the install process w/o the PEC and then attempt to show the same thing after the changes that I made so I can use the bagger w/the PEC. Hope I can stay logged on long enough to finish.
The pickup chute is really simple to install, fold the deflector all the way back and slip the forks over the back edge of the chute, then the thumb screw goes in from the top and holds the thing together.
/ Bagger Install
Normally when mowing, the lift links are disconnected from the rockshaft arms and pinned to the brackets on the frame so they don't lower when the deck is lowered. To hook to the bagger, the instructions say to remove these links from the lower lift arms also and there are brackets on the bagger frame to store these links while the bagger is in use, I left these attached to the lower arms and held them back with a stretch cord.
/ Bagger Install
The lower lift arms have to be held up as you move the bagger close to connect the top link bracket, you can just tilt the bagger forward after it is close and insert the top link pin.
/ Bagger Install
The right side with the blower is a little heavier, but it wasn't hard to pick it up about and inch to get the lift arm to slide on the pin. I know some have used a piece of board under the stand on each side and that will probably eliminate picking up each side to get the arms on the pins.
All that is left is connect the PTO and the hose. I had the PTO cover off the tractor to get a better picture, don't try this at home.;)
/ Bagger Install
With these brackets I made, I can leave the PEC on and leave the lift links attached to lift arms and leave them attached to the brackets on the frame of the tractor, the same way it is if I'm mowing any other time without the bagger, just back up to the bagger and hook it up. Here are the brackets that go on without altering anything at all on the bagger, and the way the three point looks when I normally mow.
/ Bagger Install
With the PEC, there's a hook, and just lift the right side and drop the bar in the hook.
/ Bagger Install
Around to the left side and lift it up and drop it in the hook.
/ Bagger Install
It's hooked in the lower lift arms, just tilt it forward and insert the top link pin and connect the PTO.
/ Bagger Install
All ready to suck. Don't forget to raise the stands, did that once.:D
/ Bagger Install
Sorry about the long delay, I have the Kubota bagger, and I like the way it works, several have complained about it being a bear to put on, but before I made the mods, I had it on and off a couple of times and after a little practice, it's not that bad. One of the main reasons I went with this one is that it is powered by the PTO, no extra gas engine, so much quieter that way.
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
1991 John Deere 4455 (A64126)
1991 John Deere...
2016 Ford Explorer AWD SUV (A64557)
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
