bagger for ballast?
/ bagger for ballast? #1
stevess
can a 3 bucket bagger offer enough weight on the back of a riding lawnmower with snowblower? i was thinking of adding a few bags of sand. anyone use this type of setup for snow removal? my ride is an older 13hp ariens with a 36" sno.
thanks
steve
/ bagger for ballast? #2
I would not use the bagger simply
because the bagger will not handle
the weight and it will tear and
become useless.
You will be further ahead having
the tires loaded with windshield
washer fluid to aid in your snow
removal as you will have much
more traction with some wind
shield washer fluid in the rears.
/ bagger for ballast? #3
I am thinking of using my bagger also. It has three plastic bins. I estimate that each bin will hold 50+ lbs without damaging anything on the bin or tractor mounting bracket. I also bought wheel weights and have chains. Will probably put fluid in the tires also as I need more traction when in reverse. By the way I also weigh 220 lbs. Maybe you should eat more????:laughing:
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A67147)
2020 FREIGHTLINER...
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A64556)
2014 International...
2022 EZ-GO ELITE...
2018 CATERPILLAR 320GC EXCAVATOR (A65053)
2018 CATERPILLAR...
