HEC
Veteran Member
I just bought a new land pride 5 ft. R.C. and tried to mow with it today and it vibrates badly on the B2650 , not just when you start up but costantly like it is out of balance . I have used and old bush hog for the past 25 yrs. so I am use to rotary cutters . I checked the blades to make sure they would rotate ok . I sprayed some lubricant where the blades swivel and that helped until I shut it off and started back up again later . I tried it on the B2650 first as that is what the dealer said I needed . I then put it on my M5700 and it would even vibrate that tractor .I don't know if it is out of balance or the blades just are not free enough to swivel like they should . It is the med. duty cutter rcr 1860 .
