Bad stuff
/ Bad stuff #1
mrolson
Will County,IL
Kabota L3000DT, 1944 Farmall M, JD345
Sorry for the bad topic. I had to put down the in-laws dog last November. The vet wanted an additional $30 for disposal and I should have taken them up on it. Yesterday I can’t get my dog in from the back. I drive over and find the coyotes have dug up what should be left alone. If my wife finds out, she will go nuts. I dug a few feet deeper (as far as I could) and placed rocks before reburying. I put a BIG rock on top. I get up this morning a find they have been digging some more. Does anyone have any experience or suggestions about this?
/ Bad stuff #2
Mark,
This is something we have been known to do to get rid of unwanted bears, can't imagine why it wouldn't work on coyotes. Take a can of all that old cooking grease, old bacon fat etc. most everyone I know has one in the kitchen. Lace it full of Cayane pepper and anything else hot and nasty you can think of. Mix it up real good and then smear some of it around where the coyotes have been digging. They will smell that and think there in doggy bacon heaven untill the pepper kicks in. You may hear them howling, but it won't be at the moon. Works Fantastic on bears,
/ Bad stuff #3
Mark--
If they actually dig up the remains again, I think that scattering lime before reburying is a time-tried way of minimizing grave digging by varmits. I'd guess there is enough scent around the gravesite now that the coyotes are just digging based on surface scent; I wonder, without knowing, whether spraying bleach or something like that would discourage them.
--Rick
/ Bad stuff #4
My experience - bury them as deep as possible, use as many stones as possible and stack a good sized pile of stones on top. Never had one dug up and we have lots of coyotes.
/ Bad stuff #5
Had the almost same problem when my wife burried our dog in a too shallow grave.....I coiled some barbed wire around the site,and all was well.
/ Bad stuff #6
Mark,had the same problem,I mixed moth balls in the top layer of soil and around the grave.No more digging by varments.
/ Bad stuff #7
Yes Mark. I agree with the mothball remedy. The stench from these things will chase anything away until they lose their potency. You can periodically replace these until the critter problem is solved.
/ Bad stuff #8
Try putting some lime over the area before they return.
/ Bad stuff #9
It's too late this time, but I always put the body in a large garbage bag to reduce the scent. Not very ceremonious, but better than the situation you are experiencing. Bury as deep as you can.
My dog cemetery is well in front of my house; only about 200 ft from a well-traveled road. This probably also has reduced grave disturbance over the years.
I think the lime only works if it is placed directly on the body. The moth ball idea should work regardless. My experience says that the hot pepper idea is unlikely to work on hungry canids unless they have easy access to other food sources (i.e. burning your mouth beats starving).
/ Bad stuff #10
I have had much success with crushed pepper flakes and ground hot pepper. I don't mix it with anything. Sprinkle liberally on the body and then after every couple of layers of dirt. Then lots in the top layer of dirt and on the surface. I think it may mask the scent of the animal that has been buried. Also if a carnivore takes a sniff it will get a snoutful of burn and be pretty gun-shy about coming back.
I am a little leary of mothballs as deterents. They use to be made of napthalene which is pretty nasty stuff. Not something I want in my soil. I have had neighbors who swear by them. Especially for keeping cats away. But I still am overly cautious.
Phil
/ Bad stuff
Lots of great ideas. If I had to do it over, the secret seems to be dig DEEP and a bag of lime. (I guess that’s justifies me getting that backhoe /w3tcompact/icons/wink.gif). But, since Coco has already been is been buried twice, I will dump some big rocks around the site. I guess it will be considered a monument. I will mix some moth balls on the outer edges as well. I really don’t want to use the pepper because our animals. It’s amazing how well these coyotes dig. Thanks for all the ideas
/ Bad stuff #12
Unfortunatly I too have a pet graveyard started at my place( I have only been here 2 yrs), I put the animals in trashbags then buried them. I have had no problems with scavengers and we have plenty around.
/ Bad stuff #13
I usually dig a post hole in the ground, (depending on the size of the deceased one), and it keeps the soil undisturbed around the hole, making digging more difficult (apparently as it never has been a problem). Depth is such to get about 20-24 inches of soil over the carcass. Add one rock at the top of the hole and it makes for a neat burial site.
The lime is put in to help speed up decay of the deceased. Likely helps with the smell too.
/ Bad stuff #14
When we put down a pet cat a couple of years back, I buried him about 12-18" down and then covered the grave with a bunch of stones. Never had any problem with scavaging beasts.
Terry
/ Bad stuff #15
I've buried 3 dogs on our property as well as 1 dog and many cats on my parents property. All lived long, happy lives and I had to have them put down due to complications from old age. Here's how I buried them.
The vet gave them to me in a very heavy plastic bag, which I believe helps keep the scent in. I dug a hole as deep as possible( almost 4 feet) with my manual post hole digger, then started widening it by shearing off the sides. I made the shape of the hole only large enough to lay the animal down in. I put at least 2-3 more heavy duty plastic bags over the one that the vet gives us. Then I lay the animal in the hole. I back fill it about a foot, tamp it down and repeat until the hole is filled. I even hill it up about a little to compensate for the settling of the animal. That's it. Never had a problem.
Hope this helps.
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
2011 JET  48 FOOT SPREAD AXLE STEP DECK TRAILER (A67714)
2011 JET 48 FOOT...
MAHINDRA 2538 TRACTOR (A65057)
MAHINDRA 2538...
2016 Bomag BW90 AD-5 Tandem Vibratory Smooth Drum Roller (A66734)
2016 Bomag BW90...
2005 CATERPILLAR TH460B TELESCOPIC FORKLIFT (A65056)
2005 CATERPILLAR...
