Bad pressure gauge?
/ Bad pressure gauge? #1
ning
Elite Member
Northern California
Branson 3520h
I set up a 5000psi pressure gauge with M&F connectors, stuck it on my backhoe loop, and operated a valve (briefly deadheading).
The dial didn't budge.
Fluid is definitely flowing through the line.
Bad gauge, or is this not a good place to put a gauge?
/ Bad pressure gauge? #2
Could you have, accidentally, put it on the return side?
I can't assume anything today lol
I'll put it on both sides next time I have the backhoe on!
Question - what parts of the hydraulic system have pressure all the time?
I assume that there's pressure everywhere after the hydraulic pump; a line then goes to the steering, one to the loader valve block, one to the remotes, one to the backhoe? Or is the backhoe line somehow not pressurized without the backhoe actually being connected?
/ Bad pressure gauge? #4
With an open center hydraulic system just like yours, there is no pressure as long as all the valves are all in Neutral. There is a free path for oil to go back to the tank. Once you pull one lever and the cylinders start seeing some resistance, the pressure will start rising.
In this case, you want the gauge before the backhoe valve to get a read on the pressure of the backhoe. Ideally, you could also put the gauge right after the pump so you could check pressure on the loader, remotes, 3 pt and backhoe.
Ok. So if I wanted to check my pressure right now - with no backhoe on it - I can't just put the pressure gauge on the backhoe loop (without valves after it) and just operate eg a loader or remote valve, because there's essentially zero pressure unless you have a valve after the gauge?
I'm pretty sure my loader and remotes are 3/8", and this gauge loop is 1/2", so I'll have to wait till I have the backhoe back on the beast to check the pressure.
/ Bad pressure gauge? #6
Technically yes, if there wasn't another valve (3pt) in the circuit. So without the backhoe in the system, you have to connect the loop back together to feed the 3 pt and complete the circuit.
If you put the gauge right there in the loop, you should be able to see the pressure for the 3 pt valve. The way the 3 pt position control valve works always puts full pressure, regardless of the weight that is on the 3 pt. EDIT: When the 3 pt is being actuated.
I thought that with the 3 pt just sitting in one place there's nothing impeding the flow, and unless you're raising or lowering the hitch, there's actually no flow to the valve - or maybe it's just in neutral - and so there's effectively no pressure backup from that valve? (kinda like the steering circuit, where unless you're turning the wheel this way or that, there's no flow to/from the steering valve)
/ Bad pressure gauge? #8
Sorry, I meant " The way the 3 pt position control valve works always puts full pressure, regardless of the weight that is on the 3 pt." When the 3 pt is being actuated. Left that part out. My bad.
When the 3 pt reaches the preset height by the control lever, the flow that flows past the valve back to the tank/transmission with 0 pressure.
/ Bad pressure gauge? #9
I'm sorry but I have to disagree with your terminology on this one. While a do agree with everything you stated in regards to the gauge mounted in his "backhoe loop", unless you're talking about a tractor the likes of which I've never seen before, the "full pressure" you mentioned is losing me. I agree that the lift system (when activated) may get full flow from the pump until demand is met. Pressure, however, will only build to what is required to lift the load. With bare lift arms the required pressure would hardly register on a gauge mounted where his is located. With a heavy load on the three point, his gauge will read whatever it takes to lift it. Without that, his gauge mounted back there will won't tell him much about his system overall unless there is another valve between the gauge and the lift system he can deadhead to generate pressure. Unless that's the case here, I don't think he should be expecting to see much on his gauge.
/ Bad pressure gauge? #10
I understand what you say and I was actually surprised as well when I discovered it, although I haven't spent much time analyzing the circuit on the position control valve at the time. Anyway, I ran a pressure gauge on my tractor for quite some time. Right after the pump. Keep in mind all the 3 pt components on the OP's tractor are exactly the same as mine.
What I experienced is that every time I moved the 3 pt lever to lift the 3 pt, the pressure would go straight up to max pressure (2600 PSI), regardless if there was any weight on the 3 pt or not. As long as the 3 pt was raising, it was at max pressure, even if was just raising 1". I guess that's just the way the position control valve on these tractors work.
It's basically a closed center valve with an unloading valve.
/ Bad pressure gauge? #11
Okay, I don't mind admitting when I'm wrong. Thanks for explaining that. I'm not a Branson man. Have probably only seen one or two, and certainly was never involved with the hydraulics. The brand name tends to connect and again separate from other tractor brands over the years, so it's likely there are others that operate in the same way. I just have never been involved with any.
Funny thing about this: yesterday I used the tractor to move something heavy and long, too long to use the forks and get it through gates and down a road (a very wide roll of netting we use for fruit trees vs birds). One end I put on the tiller that's on the 3ph, the other end was on a wagon, and the pipe going through the roll that supports it usually I shoved farther in so it wouldn't stick out so far.
A while later after getting the roll set up in its new location, I found the 3ph wasn't operating. All other hydraulics were fine, I'm like "ok so NOW there's suddenly an electrical thing about this?" but no on closer inspection when I knocked the pipe it hit the backhoe loop connector that keeps the two hoses together just right and while superficially the loop looked complete because of how the hose is being held there, the two ends were no longer connected...
and I thought of this post and how "without the backhoe you have to connect the loop... for the 3ph"
Bingo!
/ Bad pressure gauge? #13
Bingo!
Good catch.
If the engine was idling, then you would probably noticed the load on the engine as the hydraulic pumps pushed fluid at max pressure through the relief valve. With the engine revved higher, it's probably less noticeable.
Did you end up getting the pressure gauge to work?
I haven't had the backhoe on yet; I may put it in the loop and watch it as I raise the 3ph and see if it shows it then. Will update.
/ Bad pressure gauge? #15
Yeah, try that and give us feedback. I'm curious now if it's indeed a bad gauge or not.
When manipulating the 3ph it briefly hits about 2500, should be good.
2008 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2008 JLG 600S...
2018 HINO 258A (A60736)
2018 HINO 258A...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
