Backhoe Bad Hydro line............
/ Bad Hydro line............ #1
mikesranch
Warren, Pa
BX 24
Pinched a return line for my left stabilizer I am unable to get wrench on connection. It is the third fitting in and there is no room to move!!! Any secret way of loosening these fitting without removing all of them. Kubota cramed alot of lines in a little space!!! Any help/ advice is appreciated!!! Tractor is A BX 24 TLB
/ Bad Hydro line............ #2
Sounds like you need a tubing wrench. Something like a box-end wrench, but has a slot to fit it on the fitting.
/ Bad Hydro line............ #3
A lot of fittings in a tight spot, means pulling some until you can get at the one you want. Usually no room for a tubing wrench. They are only good at not rounding off a fitting and require more room then an open end wrench. Anyone have a secret here ..... Please let us know. :2cents:
Jim
/ Bad Hydro line............ #4
The need to remove several hydraulic lines to get to the one damaged is not unusual.
Angle wrenches come in very handy for tight spots, plus a lot of patience. ;)
Mac
/ Bad Hydro line............ #5
+1 on what macinPA says. Pretty common to have to remove a few lines to get to the one you need.
/ Bad Hydro line............ #6
I had a really hard time getting a line off from the hydro distribution block on the BH. I made a tool by cutting a slit in a deep well socket with a cutoff disk. If you look up an oxygen sensor socket, that痴 the tool that gave me the idea. Once I made the tool I was able to get the socket on the line with just enough turn to loosen the connection and reinstall the new line.
2018 Club Car Carryall 1700 4x4 Diesel Utility Cart (A61572)
2018 Club Car...
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
JOHN DEERE 4110 TRACTOR (A64280)
JOHN DEERE 4110...
2022 John Deere 5055E (A62177)
2022 John Deere...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
