Bad day,Lost an engine
/ Bad day,Lost an engine #61
Hard to believe that they would use the same casting.....that would allow for a 7mm bore difference. That's 0.275". Mfgs are usually too lean to allow for that extra material to be wasted. .060 is more than most blocks can comfortably handle.
I am betting the smaller engine has larger coolant passages, to save material. And will not allow for that much material removal. But having a shop sonic test the walls for thickness is the only way to me sure.
And even if they are the same, I am betting something is also different in the fuel delivery system.
/ Bad day,Lost an engine #62
Parts manuals shown the 225 has cylinder liners (6695873), shows the 230 without.
/ Bad day,Lost an engine #63
Allis Chalmers used sleeves engines in their gas and diesel tractors. We did the same thing with our old super A. Rebuilt with a super C kit. Most manufacturers used wet sleeves back in the day for easier rebuilds. If they use the same block then upping the HP is easier.
/ Bad day,Lost an engine #64
Part numbers for blocks are different.
/ Bad day,Lost an engine #65
All the A's, B's and C's used the same block, (in different variations) you had to go to an "H" to get a bigger block and the next change was the "M".
I bet it saved them a LOT of money, making engines that way...
SR
Not sure I understand. They share the same block with different part numbers, but the low hp model has a sleeve, but the others do not. Is the sleeve used to lower displacement?
/ Bad day,Lost an engine #68
Adding a turbo by itself is sure to get you a cleaner burn, but to suggest that it would by that or other means gain noticeable/usable power is perhaps to confuse the simple result with gas engine application(s). Porting/polishing might (should) also offer the similar, if minor, minor gains but I'd expect no noticeable power increase without adjusting the pump for more fuel delivery, as suggested by SR & others.
'Read' your exhaust. Port, or better-yet t-charge if you see too much black smoke. (wasted fuel as 'tuned/tweaked') I agree that replacing with a reman, other short block, etc is the better way to up displacement, but a 'turbo & turn-up' is the only difference between an awful lot of similar class/wt machines within a brand/line, so why not if the c-shaft, rods, etc are common to the higher hp versions and up to the job. (Do have one guy do the crank & bearings as said regardless of the other bits)
btw, IMO having injectors checked/flow-matched is never a bad idea or offers a bad ROI, esp if compared to a few weeks/months worth of scratch-off Lottery tickets. :D Good luck! "I'm pullin' for ya!" :)
Can the pump on a 225 be adjusted for more flow or will I have to replace it with a 230 or 235 model injector?
I keep coming back to the question. How does the 230 make the extra 3 hp. I know 3 hp does not seem like a lot,but on this machine, it is about 10%.
/ Bad day,Lost an engine #70
May not understand because there is conversation about Allis Chalmers and Bobcat. The Bobcat 225 and 230 do not share the same block. According to Bobcat parts manual they have different part numbers plus the 230 block has cylinder sleeves. The 225 does not. I am saying they are completly different based on that information.
There is 6.1 cubic inches difference, I have no idea whether that is the only factor in the hp difference. Wouldn't doubt it but pure speculation on my part.
Further research shows both 225 and 230 use the same injection pump.
2016 Terex RL4 Towable Light Tower (A60352)
2016 Terex RL4...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
YANMAR XIO35-6A EXCAVATOR (A59823)
YANMAR XIO35-6A...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
