Backhoe Bad day: flipped backhoe, then almost flipped tractor...
   / Bad day: flipped backhoe, then almost flipped tractor...
Regarding implement used to lift/move the BH, I can see that the grapple wasn't a great idea (though I might well have done the same). I would think that a tree boom on the loader with chain or straps to the BH might be even safer than forks. Wouldn't lifting from above provide more stability than using forks below a top heavy BH/dolly?
Some of the difficulty of lifting from above is clearances and COG. I only have 8'H overhead electric doors in the main section of the barn, so having the loader, or a tree boom on the FEL arms would have to clear the top of the dipper/boom peak point and still be under the OH door when I go to push/pull the hoe into the bay from the leading edge of the floor after it's been removed from the tractor, placed on the dolly, and having removed the hoe I have only loaded tires for ballast, once I turn the tractor around to maneuver the hoe/dolly into the bay.
I've had good luck so far using the forks to place under the hoe station while riding over the subframe, as I remember the sequence. I'm still at some risk of loosing the whole rig if the hoe were to slide/slip/drop off balance from the forks. This could render the hoe AND tractor susceptible to laying over while I try to escape or stay strapped in place on the tractor. One other possibility is the adjacent unheated bay that houses my boat over winter. The problem there is not that I have a 12'H OH door, with plenty of clearance; the problem lies in not having much space to maneuver the hoe on the dolly in front of the boat. I built big, but not that big.
I'll have to look at the remaining space to see what might work. I'd rather have the hoe in my heated bays, but I could rethink that need.
What does a tree boom look like, exactly? Do you use one, IT?
IslandTractor is spot on. The BH has an inherently high center of gravity, and when not on the tractor tends to be tippy. Here's a dolly I made for my BH77 hoe. If I were doing it again, I'd spread the two wheels further apart for more stability and use an A frame (rather than the T), as on the T frame the hoe main boom pivot sags down to sit on the frame - not a big deal, but does flex the frame. Also, when I modify it, I'll make latches to go over the top of the pin cradles - shown are simple cups, which work fine, but if spreading the wheels apart for added anti-tip, it does no good if the hoe support points are narrow without locking it down.
The cradle is used on concrete, even so, the hard rubber tread is too soft - would be better of with either hard urethane of steel wheels.
I hear you on the wheel construction, something that rolls easily, takes a LOT of weight, without flat spots forming and preferably steel or hard poly.
Where does one find these wheels? I have a H Depot, but no real other choices unless online somewhere....
best I've found is 5" poly wheel each at 350#s?!
I agree on the A-frame design. Right now I only have a approximately 2 x 2' square dolly made of 2 x 12's. It's WAY too small, and offers NO extended support like a A-frame would. I may design a similar platform to what I have, bigger with outriggers to provide lateral and front to back support. My original thought was to keep it compact and storable by reducing the overall footprint. I do have two metal with rubber wheel dollies that I was also thinking of incorporating into the design, but I'm not a real brainiac when it comes to wood and metal fabrication....
Here is the BX BH dolly. Note 4 wheels, a cross support for the bucket, and locating stops for proper positioning. It rolls under the mounted BH until it contacts the tractor. Then you use the hydraulics and pull the connection pins. Fairly easy to do.
Seems to do the job well. Any pics of the hoe on the dolly? How much does your hoe weigh?
And yes I do need to keep in mind how much clearance is available to get the dolly under the hoe and the hoe off the tractor without a height conflict....
Thanks all. Keep the ideas, comments coming....:)
   / Bad day: flipped backhoe, then almost flipped tractor... #32
I'll find some better photos of my tree boom when I get home. I have a photo of my tree boom lifting a swim float (and my neighbor) on my iPhone so will post that.
No problem with garage doors as the tree boom can be set either above or below the level of the bucket.
Photo shows the tree boom lifting to max height but I could just as easily "dump" the tree boom down to pick up something at ground level.
   / Bad day: flipped backhoe, then almost flipped tractor... #33
Echo everyones concern and happiness you came out unscathed. I enjoy learning on TBN almost as much as some people love spending others money (guilty). Last year I plowed without my counterweight on and it was hairy to say the least, its going on this year without fail.
Again, thanks for posting, some may be to proud to share their mistakes or accidents, but you served to make me again think EVERY time about how easily this thing could kill me!
   / Bad day: flipped backhoe, then almost flipped tractor... #34
Here are some better photos of the tree boom. It is a SSQA implement with no moving parts other than a couple of shackles. There are two attachment points on the boom, at the middle and at the end. It essentially converts the FEL into a mini crane. I've used it to lift a number of pretty heavy items and I find it much better and safer than lifting top heavy items with forks. I use both chain and sometimes straps to attach to the load. We pull the swimming raft (1500lbs) up over a seawall by dropping the tree boom over the edge then curling and lifting. I use it to move implements on and off a trailer. One thing I have never used it for is moving a tree root ball which is where it got it's name.
   / Bad day: flipped backhoe, then almost flipped tractor... #35
That thing looks useful but dangerous.
Looks good! Who makes it? Thanks for the pics too. I can't make out the brand name on the pic with the boom on the ground?
   / Bad day: flipped backhoe, then almost flipped tractor... #37
It's a fairly generic implement. Mine is from Millonzi but they have been out of business for years. I just did a quick google search and found one at palletforks.com for $295.
It is also an ideal DYI project as there are no moving parts or critical tolerances.
   / Bad day: flipped backhoe, then almost flipped tractor... #38
You can buy a "blank" SSQA mounting plate in various thicknesses from a number of sources. The plate saves cutting and welding the "hard part" of a SSQA attachment. Here's one on Amazon for $144 (free shipping).
Amazon.com: Titan 5/16 Quick Attach Attachment Mount Plate Skid steer bobcat kubota 516MP: Home Improvement
I used a similar plate to make an item specific set of forks to pick up and move a 500 lb hydraulic man lift. The lift has wheels, but there's no good way to move it over non-smooth or paved surfaces. Moving it around with the tractor is a breeze (goes up to 30' working height so is great for cleaning gutters etc.
bumper
bumper
I have two: one for my sickle bar, and another with a receiver hitch female end welded on to move my boat and other trailered items around my yard.
   / Bad day: flipped backhoe, then almost flipped tractor... #40
Hi Coyote Machine,
I picked up some decent steel wheeled casters at TSC, not as big a diameter as you werecmentioning, more like 6", but about 3 or 4" wide too.
These are the ones:
Titan Casters 6 in. Heavy-Duty Steel Plate Caster, Swivel, 900 lb. Capacity - For Life Out Here
These are bigger though:
Bulldog Detachable Steel Caster Wheel Assembly - For Life Out Here. -Solid, but pricey
Thomas
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
S/N: 1240824 (A55853)
More info coming soon! (A56859)
More info coming...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
