Bad Boy Zero Turn Safety Devices
/ Bad Boy Zero Turn Safety Devices #1
JMAC1966
Bad Boy 54" 7000 Series Koehler
Can anyone tell me how to bypass the safety devices so you can get off without it dying? It's not just unplugging the seat switch. I did that and you couldn't manipulate the parking brake or pull in the steering arms without it dying. I just want to be able to jump off real quick, move a branch or rock and pick up trash. Thanks.
/ Bad Boy Zero Turn Safety Devices #2
You should just have to set the brake and shut off the PTO to keep the engine running. I wouldn't try to over ride the PTO safety.
/ Bad Boy Zero Turn Safety Devices #3
Yep. Turn off the PTO, apply the parking brake then move the handles out. I keep getting the last two out of order so it might be the other way around. :rolleyes:
I'm pretty sure it dies if you move the handles out first so apply the parking brake. I'm always jumping off mine to pick up fallen branches that look too large to cut up.
/ Bad Boy Zero Turn Safety Devices #4
keep a hand picker upper on the mower. you will be surprised at what you can pick up with a picker upper
/ Bad Boy Zero Turn Safety Devices #5
That doesn't work with mine. It's a 60" cut and the seat kill switch doesn't allow you to lean over much. And you certainly can't reach it from the front. If you're close enough to pick it up, you probably already ran over it. :oops: Even so, what do you do with it after you pick it up? :(
/ Bad Boy Zero Turn Safety Devices #6
put it on the floor board. have a garbage can near where you keep your mower and when you get a few pieces on the floor drive over to the garbage can and toss it in and go back to mowing
/ Bad Boy Zero Turn Safety Devices #7
^^ It's getting easier for me to spot AI generated drivel.
/ Bad Boy Zero Turn Safety Devices #8
Yeah, where I keep my mower might be over a quarter mile or more from where I'm cutting. And for sure, no one is going to keep Mesquite branches piled up under their legs or feet. :rolleyes:
This thread is from last year. :cool:
On a side note though, I did just buy the "Zero Turn Mower Handle" that comes with a bucket holder. (I've got plenty of 5-gallon buckets.) I also bought a long and heavy duty folding grabber I'll be trying out soon. The clamp for the handle didn't fit my Bad Boy so I just drilled and tapped the front bar. The handle is pretty strong and an aid to get on and off the mower.
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
1990 Bayliner 19ft Trophy Center Console Boat w/ S/A 20ft Boat Trailer (A59231)
1990 Bayliner 19ft...
