Bad Boy Magnum issues
   / Bad Boy Magnum issues #11
Have you tried clear gas twgoats?
No, I would like to, in all my small engines, but I haven't found place around here that sells it.
   / Bad Boy Magnum issues #13
It may be something to try if you can get your hands on it. Or possibly fuel from a different station, different blend etc. There has been some scuttlebutt on vapor locking or fuel boiling due to the alcohol content causing stalls and stumbles and such.
I have tried gas from different station/brands and the issue continues. With the difference in flashpoints of over 110 degrees, I do see a possibility of vapor lock. I also have a friend, who while a bit of a conspiracy theorist, makes a case for the fact that since alcohol can displace/absorb up to its weight in water that E-10 gas (can?) contains 10% water coming from the pump.
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
