Bad Boy Magnum issues
   / Bad Boy Magnum issues #11
Have you tried clear gas twgoats?
No, I would like to, in all my small engines, but I haven't found place around here that sells it.
   / Bad Boy Magnum issues #13
It may be something to try if you can get your hands on it. Or possibly fuel from a different station, different blend etc. There has been some scuttlebutt on vapor locking or fuel boiling due to the alcohol content causing stalls and stumbles and such.
I have tried gas from different station/brands and the issue continues. With the difference in flashpoints of over 110 degrees, I do see a possibility of vapor lock. I also have a friend, who while a bit of a conspiracy theorist, makes a case for the fact that since alcohol can displace/absorb up to its weight in water that E-10 gas (can?) contains 10% water coming from the pump.
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
Zero Turn Mower (A48082)
Zero Turn Mower...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2008 FREIGHTLINER FLD120 SD DAYCAB (A50854)
2008 FREIGHTLINER...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
