Bad Boy Magnum issues
   / Bad Boy Magnum issues #11
Have you tried clear gas twgoats?
No, I would like to, in all my small engines, but I haven't found place around here that sells it.
   / Bad Boy Magnum issues #13
It may be something to try if you can get your hands on it. Or possibly fuel from a different station, different blend etc. There has been some scuttlebutt on vapor locking or fuel boiling due to the alcohol content causing stalls and stumbles and such.
I have tried gas from different station/brands and the issue continues. With the difference in flashpoints of over 110 degrees, I do see a possibility of vapor lock. I also have a friend, who while a bit of a conspiracy theorist, makes a case for the fact that since alcohol can displace/absorb up to its weight in water that E-10 gas (can?) contains 10% water coming from the pump.
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
INSPECTION (A51573)
INSPECTION (A51573)
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
