Backpack sprayer/fogger?
/ Backpack sprayer/fogger? #1
ning
Elite Member
Northern California
Branson 3520h
I've been looking into getting a backpack fogger for spraying horticultural oil in our little orchard.
We've used a small powered sprayer unit before, but it broke rapidly, and in researching a replacement I ran into the fogging idea, which is that the fog of stuff makes a much more efficient cover of the whole tree - efficient in time and the volume of "stuff" used.
Note that the horticultural oil (neem oil) is emulsified and is basically a water solution.
I'm curious about the Stihl SR 200, 430 and 450 units. Someone local around here (on "nextdoor") says he's got the 430 and uses is for neem oil and it works great; I'm curious if anyone out in TBN-land has used one of these units for the same - or a similar non-Stihl unit.
Most of our trees are dwarf- to semi-dwarf; I keep them pruned to about 10' height.
So one question is whether the SR200 will fog that height well enough; there are some indications that you need to add a power pump to help move the fluid into the air stream on the SR 200 to reach higher elevations; I believe the SR 450 comes with it, the SR 430 not. Unclear.
The 200 is a lot cheaper than the 430/450, but it's got 1/3 the engine (and weighs 9 pounds less). It's also got a smaller tank, but for our use its tank is a fine size and I'm not expecting to carry a full load in any of them.
Any experience with any of these foggers? (If you do have experience but it's for insecticide, I'm still interested in how you like the machines).
/ Backpack sprayer/fogger? #2
We just have 2 peach trees, 1 apple tree and a pear tree.
Could I just put the neam oil in a sprayer to apply it to our trees?
I did see an add on to a leaf blower on Amazon. I wonder how it would work?
/ Backpack sprayer/fogger? #3
I’ve used a similar one on a small orchard, and getting even coverage really makes a difference. The SR 430 sounds like it might be a good balance between power and ease of use for your 10‑foot trees. I’ve seen some chatter about the SR 200 needing an extra pump for higher coverage, so if you’re aiming to spray up to the top, that might be something to consider.
/ Backpack sprayer/fogger? #4
We use the 25 gallon UTV sprayer from agrisupply for our 190+ fruit trees, 100+ grape vines. Thankfully we haven't had a need/don't to spray blackberries or blueberries.
That sprayer worked great for about 2 ish years then I replace the pump and we are off to the races again.
Prior to this I indeed did the pump up sprayers. Worked fine, reach wasn;t as good but it met our needs as the trees were smaller then.
These backpack sprayers are basically a backpack blower + tank + metering device, so similar in concept.
From what I can tell, all three units (200, 430, 450) require the extra pump for higher angles - this is found on all three product pages:
"The pressure pump kit is recommended for applications in which the spray tube is held at an upward angle of more than 30 degrees in order to maintain a consistent discharge rate."
Given that my trees are pretty short, I can be well within the maximum spray range of even the small unit (SR 200 - 29.5' max range) and the top of the tree is below 30° inclination, so I suspect they'd all manage similarly; the bigger units would likely be used at less than wide open throttle.
We also tried the 25 gallon type (20 gallon I think) but it's pretty clear from reviews everywhere that all of the smaller units are pretty iffy on quality and our experience was similar; looking for a decent one was where I encountered the backpack sprayers, and everything indicates that they use less product and get a better coverage, more quickly - the time being pretty key for me as like everyone I've too much to do already.
/ Backpack sprayer/fogger? #6
We have two Stihl - an SR400 older unit and a newer SR450 and use them for fogging oils to prevent and manage insects and wiltpruf in the fall, then mosquito fogging in the summer.
Both units can fog up to 15-18' from the ground but I prefer the older SR400 as it has a smaller nozzle - higher velocity air, vs the 450 has more CFM but lower velocity. My SR450 does not have a pump.
Also there is an air feed to the tank, and if you increase the hole size in the fitting in the tank, it pressurizes the tank better and fogs higher.
I would get at least the 430 and see if they have a removable, narrower tip for the end of the blower to get more velocity get that or fab one out of a plastic bottle etc.
/ Backpack sprayer/fogger? #7
The point of the pump and the 30* angle is that once you get the tip of the nozzle higher than the tank and fluid it can't push the fluid to the nozzle (not enough pressure build up).
That's why with the smaller nozzle create back pressure, thus pushing more air into the tank.
Sorta have to use one to understand how they work.
Ok, this is what I was hoping to see with this thread! Thank you!
/ Backpack sprayer/fogger? #9
To get the tops or tips of the trees or high shrubs, you need to create a shower effect with the fogger "pulsing" of the engine or stand further back and let it fall - it's not easy in windy conditions - best to do early AM and no wind. If you have an orchard - do it from a truck or wagon bed with someone driving to gain the height
Or tractor bucket? :LOL:
/ Backpack sprayer/fogger? #11
We have had a northern tool 25 gallon sprayer for a long time. I forget if it came with a 100' hose, or I put one on, but it has no trouble spraying with good coverage 15' in the air. I haven't done a side by side with a fogger, but my suspicion is the fogger gets the undersides better with less waste.
I'd try the neem oil first. It wasn't very effective here, but IIRC, I was just trying to cut down some aphids.
All the best,
Peter
/ Backpack sprayer/fogger? #12
I went about looking at back pack sprayers also, as well as ATV broadcast sprayers. Just an FYI, if looking at Fimco 25gallon tank sprayers, they make consumer grade models under the Fimco name, and agricultural/commercial models under the Agspray name. The Fimco's are cheaply made. "pretty iffy on quality" would be my experience as well. Mine lasted a very short time before things started to fail. However the Agspray model I have now I would recommend. Robust and well designed unit:
A local fellow invited me to check out his sprayer. He's got the Stihl SR450, but he regularly uses the SR200 as well at his job on a (legal) cannabis farm.
It seemed to me that the amount of "stuff" (there was only water in the tank today for demonstrating) had any problem being blasted into the air flow with the arm pointed up pretty high.
He said for what I'm going to use it for the SR200 would be more than enough, though if you want to dust with diatomaceous earth you do need the bigger unit which allows you to run powder through it.
so basically
SR200 $480, empty weight 19#, blows ~30', 1hp, 2.1 gal container
SR450 $800, empty weight 28#, blows ~48', 4hp, 3.7 gal container
With less than a gallon of water in the SR450, the pack didn't seem killer heavy; I've worn 50-pound backpacks on longer hikes before and the majority of my trees are on flat land, so I'm not too concerned about the weight... and my wife would probably complain about the weight with the smaller unit anyways.
unless I convince myself that I'd like to dust with diatomaceous earth, I'm pretty sure I'll get the SR200.
/ Backpack sprayer/fogger? #14
I have my SR450 on a platform behind the seat on my Cub Cadet 1811 and spray 5-6 acres for mosquitoes. The fully loaded sprayer is 60Lbs - more than I want to carry over this area every two weeks, When I was 50-55 no problem, but at almost 70 it gets heavy fast.
For treating 20 or so trees/shrubs with 2 gal the SR400 on the backpack is easy. as you need to move a lot more to get the coverage on the trees and shrubs.
Sounds like the SR200 will do what you want - good you were able to test drive before buying!
I was considering if something could be rigged up to use our mower like that. Considering there's currently no seat on it (just the flat metal base that the old seat was on before it got terribly cracked and water logged) I guess setting up a little rack would be easy and it would be in the same position as on a back.
But, as you mentioned having to move around a lot would be a pain on the mower...
(I've considered getting a new seat but they appear to be about $100 or more and the mower is over 15 years old and I just know that if I spend money on a seat the mower's going to die spectacularly causing that to be a waste of money... but then driving it on our bumpy land is nasty ow ow ow)
