Backpack Blowers
/ Backpack Blowers #21
If you are use to walking around all day with 25 # (this is what mine weights) hanging on your back you should be ok.. After about 2 hrs of constant use.. I take a break
/ Backpack Blowers #22
FWIW, Stihl offers a padded hip belt as an option on their backpack blowers and foggers to relieve back strain. I have the belt on my BR600 and use it for any "extended" session of blowing. The stock hip pad on the bottom of the blower gets swapped out for the belt. Stilh also offers a chest belt.
Object moved
/ Backpack Blowers #23
I have a handheld blower that does a good job, but even though I am a fairly big guy, hanging on to them with one hand doesn't work long as I need to switch hands very often. I need to consider one of those backpack blowers but never used one. The question is, are they fatiguing?????/
Yes, but not as bad as a regular blower. Walking around with one of these for 2 hours is tiring, but walking around with a hand held for 8 hours is harder.
/ Backpack Blowers
Not much since the weight is balanced and your arms aren't taking the weight. Much less fatigue and certainly less than a hand held used for a much longer time t get the same job done.
/ Backpack Blowers #25
I have a husky ,,best use for it is cleaning eaves or gutters , i use an old down pipe with an elbow on top end as an extension,,just walk around house , no climbing ladders,,also burning brush
/ Backpack Blowers
Great idea.
/ Backpack Blowers #28
I use my Stihl blower to clear snow off the deck and walk ways.
Depending on the snow it works a whole lot faster than a shovel.
Also makes de-cobwebbing the barn and delouseing the work shop a
Breeze. Oops, pardon the pun.
B John
/ Backpack Blowers #30
Object moved
Thanks for posting. Have to check that out next time I go to my dealer for something.
Something else I thought about is hearing protection. I try to preserve what I have left by wearing both foam plugs and a good headset.
/ Backpack Blowers
Right. Even though the BR600 4mix is relatively quiet, I still wear industrial hearing protection.
New 40' Double side door Container (A62679)
New 40' Double...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2017 International 4300 Box Truck (A62613)
2017 International...
Kewanee 12A Cultamulcher (A66408)
Kewanee 12A...
2003 GMC C4500 Crew Cab Dump (A62613)
2003 GMC C4500...
