Backhoes for a 955
/ Backhoes for a 955 #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
I know the #7 backhoe fits the 955, but are there any other models of JD hoes that will mount to the 955? Just trying to see if I can broaden my search... I just don't ever seem to run across a #7.
I know there are a number of aftermarket hoes, but a few that I've seen are 3pt models with subframe. If I get a hoe, I want to get one with a subframe.
/ Backhoes for a 955 #2
Unfortunately, you're pretty limited to what you can install on a 955. Those are great tractors, but a rather small frame (and light weight) considering the horsepower.
Yeah... and mine has a half-dozen more hp than it's supposed to.
Kind of figured I was stuck with the #7.... or an aftermarket.
/ Backhoes for a 955 #4
Woods seems to be the most popular and quality aftermarket backhoe. It might be worth checking to see if they have a setup for your 955.
There's a Great Bend 751 for sale near me... but I can't seem to find any specs for online. I've heard that Ameriquip builds the JD#7 and also builds the Great Bend, but I don't know which Great Bend model is comparable to the #7.
/ Backhoes for a 955 #6
I had the same problem, I looked high and low for a #7 and they were either 2000 miles away or ridiculously priced. So I found a New Holland 757c Sub Frame mounted Backhoe for the cheap price of 1500.00. This was also a 7 1/2 foot hoe, and only weighed a 100 pounds more then Deere # 7. So I shortened the frame a foot. Added custom welded mounts and bolted it up. It works great and plugs right into my power beyond kit.
/ Backhoes for a 955 #7
Don't know if your still looking but the model #7 is a toy compared to the woods. I have a woods BH7500 on my 855 and it will pull the tractor around. Came straight from Woods with a subframe #9285.
/ Backhoes for a 955 #8
How did you acquire the extra HP? I am thinking of buying the Harbor Freight 16KW pto generator which requires 30HP to generate full power.
THanks!
Schulte XH1500 (A64911)
Schulte XH1500...
2007 INTERNATIONAL 4300 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A69167)
2014 INTERNATIONAL...
CAT D9H 4BBL Multishank Ripper (A68134)
CAT D9H 4BBL...
1998 TRAIL KING TK70HT HYDRAULIC TAIL TRAILER (A67714)
1998 TRAIL KING...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
