John Deere 790 subframe compatibility
   / John Deere 790 subframe compatibility #1
Viggen
John Deere 790
I own a John Deere 790 sub compact tractor. I want a backhoe for my unit. What is the compatibility like with model 7 backhoes from other tractors? Do any other subframes fit exactly, or with little modification? I'm specifically looking at a 7 backhoe that is originally off of a 955. Hoping that could work.
Not sure if this is the right section or not to ask this.
Thanks.
   / John Deere 790 subframe compatibility #2
I'm fairly certain the model 770 uses the exact same frame as the 790.
   / John Deere 790 subframe compatibility #3
The 750, 770, 790 and 3005 were all basically the same model tractor that were revised over the years. All but the 3005 were at one time availible with the Model 70 loader and Model 7 backhoe (I'm not 100% certain about the 750 though). The 55 series CUTS were another breed altogether, main difference being the hydro but sizing was not the same either. So a 755 was a bit smaller than a 750. I'm not sure that the subframe from the 955 will work, but it may be close. It might be something that a good fabricator can adapt.
