Backhoe Backhoe work L39
/ Backhoe work L39
Digging around a tree for hours at a time is dangerous. You are loosening the roots and taking away the trees support. The wind could blow it down on top of you. That 70' tree would make a huge dent in the FOPS.
I have had operators with decades of experience take down trees that size with 20 ton and larger excavators. They do it in a scoop or three and can control the tree. Even they are reluctant to attack a tree their machine will not pick up.
Why not cut the trees with a chainsaw at shoulder height then dig up the roots and push the stump over with the FEL?
I was trying to use the momentum of the tree to popup the rootball as just digging half of it took about 3 hours. Ended up cutting it with a chain saw as it only came half down and hung up in another tree. Ended up taking many hours to get the rootball out. It was almost the size of the tractor and far to heavy for the tractor to lift. Had to cut the stump right off and chain to an upper root and roll it out. Just to pull it on the driveway would only happen with the front bucket full and backhoe bucket full and fully extended.
/ Backhoe work L39 #12
Please tell me how that working with a chain saw shoulder high is safe. That is really asking for trouble and a good way to get hurt.
/ Backhoe work L39 #13
Ugh - I hate digging stumps. Give my a 40,000 pound excavator, and I could see it, but with a 9 or 10' 'hoe...yuck.
Taking the whole tree out in one shot is the way to go though, provided you don't smash yourself or your tractor by accident. There isn't much getting out of the way fast when you're digging with a backhoe. I haven't tried tearing out a big tree, but for the sub-foot diameter trees, I can usually just grab the trunks with my Woods 9000, and simply rip it out of the ground. That's some fun (and makes me do Tim Allen grunting noises too...).
JayC
/ Backhoe work L39
Having done it both ways, chainsaw and backhoe I think on smaller trees the backhoe wins hands down but with large trees I would only do it with the backhoe if the tree is leaning a bit and you know which way it will fall. I would not want to try a realy large tree straight up in case it blew over or had the slightest chance of falling the wrong way. Also not safe either way if it has a lot of large dead branches. Just my 1 cent worth canadian....
/ Backhoe work L39 #15
There is some wisdom inside of you that's beginning to shine through. :thumbsup: I tried the backhoe method when the BH was new. The first tree... piece of cake, down in 10 minutes. The second tree... got the roots loose and a slight breeze started swirling around. I sat there frozen to the seat of my new tractor watching the tree start working loose from the ground, having no idea which way it was going to go. Gave it a shove, it went down, and I decided that wasn't the smartest way to fell trees in most situations. Great method for leaners and maybe if you have the tree tied off so you can guide it down. Otherwise, not so much.
/ Backhoe work L39
Wow, thats an awesome statement and I will definitely use it. From now on I will take some rope or cable and tie the tree off in the direction I want it to fall. This would eliminate the risk of the tree falling backwards. Thanks so much for this.
FENCE PANELS (A58214)
2018 Navigator RT-6500 6,500lb Piggyback Trailer Forklift (A59228)
2018 Navigator...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2016 Freightliner...
