backhoe, trencher, renting, buying...
   / backhoe, trencher, renting, buying... #41
I set the string just off the edge of the trench and about 4-6" off the ground, close to the inside edge of one back tire. If you have greater tractor clearance you could come up a bit higher. I bump the string a bit but not enough to rip in out. Only issue is when a dirt claud falls on it pinning it to the ground.
Thank you. I hadn't thought about trying to keep it along one edge either. I guess I figured it would do the best job in the center of the trench where the pipe will lay, but after doing a little trenching I can see that the trench is pretty clean along the edges, too.
   / backhoe, trencher, renting, buying... #43
Guys doing foundations/curbs, etc. set up 'batter boards' outside the trench area by a pre-determined distance [like 2'] from each side of the thickness of the wall, etc running paralell strings.
They set this up and square the corners making exact reference points. Nest time you see masons doing a block wall below grade you'll see these lines set up.
Yours would be the offset of the centerline. These guys use those 'folding' wooden rules & a level to keep things in-line.
Just dump all your spoils to the other side.
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
2017 TEREX RL4 TOWABLE LIGHT TOWER (A60429)
2017 TEREX RL4...
Deere 333G (A53317)
Deere 333G (A53317)
2012 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59904)
2012 FREIGHTLINER...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
