Backhoe backhoe stabilizer pads
/ backhoe stabilizer pads #1
BuildIdaho
Idaho
Kubota L 3400HST
Just had a new BH-75 hoe installed on my L-3400 HST. Does anybody make pads for the stabilizers? The metal feet are real hard on the area that I will be using the unit. /forums/images/graemlins/cool.gif
/ backhoe stabilizer pads #2
Build,
I got rubber grouser pads with my L39 from Kubota. You sould ask if they make them form your hoe...Otherwise it wouldn't be too hard to make a set out of wood, or thick rubber if you can find it. They just bolt up under the steel feet. It would be very simple to fabricate yourself. Good luck.
/ backhoe stabilizer pads #4
Kubota makes pads for the BH-90. I got them on mine when I purchased it. They MUST make them for your hoe as well. They were pricey.. not sure how much.. but not cheap. Well made though. Contact your dealer.
/ backhoe stabilizer pads #5
BuildIdaho
You need #L9467 rubber stabilizer flip pads for your backhoe. Two sets would be required at $52.00 each. Hope this helps.
Lewis
/ backhoe stabilizer pads #6
You might try making some out of baltic birch plywood. I use to get scraps now and then from a guy that had a buddy that worked for a company that did just that several years ago. Not a clue as to what the name of the company was but I am in the Minneapolis area if you do an internet search.
Thanks folks! I'll figure on some. Not today tho: Me and the wife are heading to Alaska for the early King and halibut...they fear me
/ backhoe stabilizer pads #9
I made a set of pads out of treated 2" x 10" for my BL4690. Used carage bolts and wing nuts for fast on/off.
See photos.
ksmmoto
/ backhoe stabilizer pads #10
Another Photo.
ksmmoto
Adams 5 T Fertilizer Spreader (A63689)
Adams 5 T...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
Speed Trailer (A64194)
2006 PROCO  130BBL (A65643)
2006 PROCO 130BBL...
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
