Backhoe backhoe stabilizer pads
/ backhoe stabilizer pads #1
BuildIdaho
Idaho
Kubota L 3400HST
Just had a new BH-75 hoe installed on my L-3400 HST. Does anybody make pads for the stabilizers? The metal feet are real hard on the area that I will be using the unit. /forums/images/graemlins/cool.gif
/ backhoe stabilizer pads #2
Build,
I got rubber grouser pads with my L39 from Kubota. You sould ask if they make them form your hoe...Otherwise it wouldn't be too hard to make a set out of wood, or thick rubber if you can find it. They just bolt up under the steel feet. It would be very simple to fabricate yourself. Good luck.
/ backhoe stabilizer pads #4
Kubota makes pads for the BH-90. I got them on mine when I purchased it. They MUST make them for your hoe as well. They were pricey.. not sure how much.. but not cheap. Well made though. Contact your dealer.
/ backhoe stabilizer pads #5
BuildIdaho
You need #L9467 rubber stabilizer flip pads for your backhoe. Two sets would be required at $52.00 each. Hope this helps.
Lewis
/ backhoe stabilizer pads #6
You might try making some out of baltic birch plywood. I use to get scraps now and then from a guy that had a buddy that worked for a company that did just that several years ago. Not a clue as to what the name of the company was but I am in the Minneapolis area if you do an internet search.
Thanks folks! I'll figure on some. Not today tho: Me and the wife are heading to Alaska for the early King and halibut...they fear me
/ backhoe stabilizer pads #9
I made a set of pads out of treated 2" x 10" for my BL4690. Used carage bolts and wing nuts for fast on/off.
See photos.
ksmmoto
/ backhoe stabilizer pads #10
Another Photo.
ksmmoto
