Backhoe Backhoe stabilizer pads installed
/ Backhoe stabilizer pads installed #21
They worked very well for me in sandy soil which is probably similar to what you have on MV. I never tried the filling bucket with rocks trick but I did dig the grapple teeth into the ground as an anchor which was not terribly effective. The Bigfoot pads made much more difference. Unfortunately, they did not fit my new backhoe so I am currently debating whether to get a new set or just make up some angle iron pieces to give me most of the function at way less cost.
/ Backhoe stabilizer pads installed #22
Huh, I certainly can't see any harm caused, so I'll look into attaching angle iron as you mentioned.
The combination of rocks and foam filled tires probably adds enough weight for me that I haven't been experiencing the issue.
/ Backhoe stabilizer pads installed #23
I put the big foot pads on my CK20 HST TLB about a month ago. Now when I use the backhoe I drag rocks or dirt to the tractor (or up in the air) instead of dragging the tractor to the rock or toward the hole. I routinley found myself dragging the tractor toward the work I as trying to do with the bucket before putting on the pads. The big foot pads are very sturdy and probably weight about 25 LBS each. These are a must from my view in the heavy rock hard soil here in northern Connecticut to effectively use the backhoe. Tractor on!
/ Backhoe stabilizer pads installed #24
My homebrew ones made a big difference. My only problem is the weight of the pad can make it tilt towards the tractor on uneven ground.
Something about digging with a backhoe,,, is just fun.
/ Backhoe stabilizer pads installed #26
Those are good pads caver. For those that weld or not, 4"x12" channel iron has worked very well in rock and dirt. So far these haven't gotten clogged with stuff, prolly because of the open ends. Their overall 12"x12" is I think the same size as the Bigfoots . . .
/ Backhoe stabilizer pads installed #27
Those channel iron pads look like they would work just as well as the BigFoot pads to keep the tractor from being pulled backwards but you'd need to weld a piece to close the ends of the channel to provide more resistance to lateral movement if you are swinging the hoe around left and right to dig. I'm thinking of doing the same thing
/ Backhoe stabilizer pads installed #28
What a great idea, I've got some of that stock at the house. I used it to build a flatbed frame for my 3/4 ton GMC Kiotihauler. I purchased for $15 per 10.5 foot length from a local shop that resells pallet racks. Great way to get affordable steel, new stock is crazy expensive.
/ Backhoe stabilizer pads installed #29
Not yet IT, digging about 40-50deg to the left and right isn't enough to drag it. If I was digging 90deg off-axis I'd move the tractor, but if that's required for a particular job I can weld endplates on. The threaded bolts/nuts sticking out might help a little too. Dirt and 'stuff' doesn't get stuck in them much cuz of the open ends . . .
My channel was 1 1/2" deep. 2" or 3" would hold mo' betta' for your bigger tractor.
btw: Re the help you gave me for adding a claw onto my bucket and hyd remotes or diverter valve and hoses/connections: I appreciate it muchly. It doesn't look like all the parts can be had for $1200 now going by the quotes I got back. Shipping is a killer, I may be able to pick up the heavy parts on this summer's road trip. Steel-Anything is outrageous too! 3X the prices I'm used to, good thing I've got leftovers to make other stuff.
/ Backhoe stabilizer pads installed #30
Hoe pads are easy enough to build and the price for ready made isn't to out of line, but why are street pads so expensive? I've heard they run around $300 for a set!
BTW, I found this thread where street pads were made from a piece of highway trash.
http://www.tractorbynet.com/forums/build-yourself/19388-street-pads-backhoe.html
I like the his setup because they can be used in dirt with just a removal of a couple of pins.
/ Backhoe stabilizer pads installed #31
Anyone know the thickness of the Bigfoot Pads? I have a CNC plasma table and I am going to cut and fab a set up for my backhoe. Looks to be 1/4" or 5/16" thick.
/ Backhoe stabilizer pads installed #32
I used to own a set. Definitely thicker than 1/4. Maybe 3/8ths. Maybe even 1/2". Pretty thick. They were made from a single piece of precision cut plate and then finished in a big press break is my guess. Need more than home workshop tp duplicate exactly. I recall thinking that I could make a functional equivalent with some heavy angle iron and a buzz box.
/ Backhoe stabilizer pads installed #33
3/8". 12 3/4" x 12 3/4" OD . The 4 bent down legs are 9" x 3" scalloped with a 2" dimension in the middle. Add 3/8" to the leg dmensions fpr OD.
/ Backhoe stabilizer pads installed #35
Here is my fabricated version of the Bigfoot Pad. Going to drop it off to be powder coated tomorrow. I will post some pics when finished. Figured I would save a few bucks doing it myself.
/ Backhoe stabilizer pads installed #36
Nicely done. Looks like you have some nice metal cutting equipment (?water jet) and a fingered press for the bends. That isnt an easy project with home shop tools. Not sure I'd bother with powder coat though it would look nice. A week or so of digging in sandy soil will take paint off just like on a bucket.
/ Backhoe stabilizer pads installed #37
I have a 4'x8' CNC Plasma Table that I create CAD cut files and it cuts the part out for me. Three parts per pad, Two of the legs were bent on a 20 ton shop press from Harbor Freight and the other two legs were welded on and then took a dealt grinder and ground the welds and radiused the edge.
/ Backhoe stabilizer pads installed #38
Clever use of press and welder. You might look at the "SWAG Off Road press brake finger break kit" (try google). Designed to work with the HF 20 ton press and would allow all of the bends to be made in the press. I have the non fingered version. Wish I had the fingered version.
/ Backhoe stabilizer pads installed #39
Here is what it looked like after bending but before I welded the 2 sides on.
/ Backhoe stabilizer pads installed #40
I have the SWAG heavy duty straight die. I will have to look at the one with the fingers too.
