Backhoe Backhoe -- rock picking techniques?
   / Backhoe -- rock picking techniques? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I have a rotten time picking up rocks on occasion with my Woods 9000 w/ 16" bucket. Sometimes they come up like nothing, other times they just slide in until I have to back up again and again. The problem usually comes when the rock is flatish and bigger than my 'hoe bucket, say 2ft or better in diameter. I try to slide the bucket under the rock, stand it up on edge, then scoop under it and pick it up on top of the bucket. If I have something to push against, it's usually no problem, but if not, the rock slides toward me when I'm trying to scoop under it.
I know, if I had a thumb on my 'hoe, this would be trivial, but I don't.
Any suggestions for rock-picking-up techniques?
JayC
   / Backhoe -- rock picking techniques? #2
Go with the trivial solution (thumb) if you have a lot of rocks to pick. Anything less will just be frustrating. If you don't have many, I suppose you could resort to driving a stake beside each rock to work against, or some sort of bumper at the back of the tractor? Maybe a bumper of some sort on the backhoe stick itself... oh wait, that's a thumb...
   / Backhoe -- rock picking techniques? #3
A few of our members made attachments for picking up rocks one was a large set of logging tongs with angle iron on the end instead of the points. to pick and place rocks. David
   / Backhoe -- rock picking techniques? #4
If you look up an old post called " rock Jaws" under attachments you will get a lot of ideas for picking up and placing rocks. Hear is a picture of one built by a member. David
   / Backhoe -- rock picking techniques? #5
A thumb that you can bolt on is probably going to be your simplist way. I know the size of the rocks that I meet with my little 12" bucket and a bigger bucket just means bigger rocks. I do find that if the rock is still embedded a bit in the dirt(or down in a hole) it seems to be easier to scoop. Failing that I shove them aside and get them with my rock forks on the FEL later on....
   / Backhoe -- rock picking techniques? #6
Bigger bucket?
That's interesting.
Yea, picking rocks is no "once in a while" thing. You can't stick a shovel into the ground without hitting a rock of some sort or another. Don't call it the "Granite State" for nothing. Digging rocks up is easy, it's picking them up once they are laying on the ground surface is the hard part - nothing to push against. I did a bunch of rock moving yesterday, the ones that cause the most grief are the ones that are around 1 1/2 times the bucket depth or bigger. They just want to roll or slide off the front of the bucket instead of laying back in it when I curl the bucket, even if I can get them all the way back to the dipper edge.
Considering how much I do this, I really should invest in a thumb, and probably will eventually.
JayC
   / Backhoe -- rock picking techniques? #8
I have moved more rocks than most quarries and my technique is to dig deep right behind the rock. I come in with the bucket pointed down at a good 45 degree angle and as I curl the bucket I push the boom down to keep the bucket as far under the rock as possible.
I also run at a higher rpm like 2500, so it curls faster and I can quickly scoop it up. Also on the larger ones, I put the loader up to it and wrap a chain around it, if I can't pick it up I can usually drag it. :D
Big Rock Pic
   / Backhoe -- rock picking techniques? #9
From another Granite Stater........ I've chased my share of rocks around my yard, and around holes that I dug to get them out. That all provided good entertainment for the neighbors, and on one occassion actually had them bringing out the lawn chairs. In the end, I found that for me, rock moving was going to have to involve getting out of the seat. :) I had a chain hook welded on the back of my backhoe bucket, and one in line with the hydraulic cylinder on my BX22 loader bucket. I found that if I could just get the lip, or teeth of either bucket under the rock, and hook a chain around it, that it would stay in place when I curled the bucket, and slide/roll in. Then I could snug the chain if necessary, and move it to the trophy pile... or a suitable resting place. I think that a toothbar on the loader bucket would probably also help a great deal.
   / Backhoe -- rock picking techniques? #10
I've pinched them against the boom. I really should fab a thumb.
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2015 Kubota L2501 (A50120)
2015 Kubota L2501...
