Backhoe Backhoe Pictorial Tutorial - Removing BH90
   / Backhoe Pictorial Tutorial - Removing BH90 #11
Thats about how the L35's backhoe comes off except it has big hooks on both sides that the backhoe rests on. Very easy to take on/off.
   / Backhoe Pictorial Tutorial - Removing BH90 #12
Excellent post and pix Don. I guess the method stated in the manual works well and would have saved me a lot of frustration if I had had the manual before attempting to remove mine.
Once you get the procedure down pat, it really is a snap to remove and reattach. The key, as I see it, is relieving the pressure in the lines!! When I get that solved, I'll be all set!
Thanks again,
bucky4
   / Backhoe Pictorial Tutorial - Removing BH90 #13
Nice series Don.
It certainly will help others in the future. Good job!
Interesting to see how the BH90 differs from the BL4690A.
   / Backhoe Pictorial Tutorial - Removing BH90 #14
I don't have a backhoe, but I am sure many others will really appreciate this post.
You have done an outstanding job documenting and commenting on the procedure and pictures.
Well done. Another example of TBN at it's finest!
   / Backhoe Pictorial Tutorial - Removing BH90 #15
That's awesome don, could I ask for one more picture? The back of the tractor showing the bh frame and the 3pt lift arms attached.
Thanks
Leroy
Leroy, The BH frame does not interfere with the 3 point hitch or T&T. See attached photo.
From the other side.
   / Backhoe Pictorial Tutorial - Removing BH90 #18
Interesting pictorial. Amazingly similar to removing the BX 'hoe with the exception that the BX "pins" are captive and spring loaded.
   / Backhoe Pictorial Tutorial - Removing BH90 #19
allo voodoo /forums/images/graemlins/grin.gif hows the iseki runnin...mines up on blocks with a flat front tire right now..gotta git a tube tomorrow
   / Backhoe Pictorial Tutorial - Removing BH90 #20
Great post. Very informative and useful to see these type of photo essays even if you don't have the machine in question.
Cliff
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
Sedan (A59231)
Sedan (A59231)
Pair of 2001XA800Z Yamaha Jet Skis (A57453)
Pair of 2001XA800Z...
5' MOWER (A52706)
5' MOWER (A52706)
