Backhoe Backhoe Pictorial Tutorial - Removing BH90
   / Backhoe Pictorial Tutorial - Removing BH90 #31
You're right Swampvol! I plan to get a BH and have wondered about the process. I bookmarked this thread. Thanks TXdon!
   / Backhoe Pictorial Tutorial - Removing BH90 #32
txdon said:
11. Disconnect hydraulic hoses on the following manner: (1.) Disconnect the inlet and outlet from the tractor. (2.) Connect tractor's outlet hose to the coupler of return hose.
One thing TXDon forgot to mention...make sure the tractor is turned off before disconnecting the hoses!!!
   / Backhoe Pictorial Tutorial - Removing BH90 #33
TXDon made that point very clear in step 9
I was thinking I might need a picture of my hand on the key on step nine to be consistent or someone might miss it.;)
I take the hoe off and on about every 6 months and still have to go step by step from the manual. The BH has been preforming flawlessly, except that one time it hit the water line.:rolleyes:
   / Backhoe Pictorial Tutorial - Removing BH90 #35
I find that get the backhoe off is much easier that putting it back on. When I raise it up with the stabilizers, it wants to move to one side or the other. One stabilizer stays put and the other slides in as I am raising the hoe. The thing that ticks me off, is it is never consistent.
   / Backhoe Pictorial Tutorial - Removing BH90 #36
Doh! That he did.
Ill be taking mine off next weekend for the first time with my laptop and this thread.:D
Again, great thread TXDon!
   / Backhoe Pictorial Tutorial - Removing BH90 #37
I use "cribbing" to keep the hoe in the raised position. When I need to reinstall the hoe,I need only to back into it and start the installation process :confused:
   / Backhoe Pictorial Tutorial - Removing BH90 #38
I thought about just sliding a floor jack under it when I go to put it back on. I'll try that next time.
   / Backhoe Pictorial Tutorial - Removing BH90 #39
Good tutorial. Same procedure for B26 backhoe. The only aspect I have some trouble with is getting the pins out. Finding the "sweet" spot that releases the pins has been a challenge for me. As you say, raising the rear wheels doesn't work.
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
401 (A52706)
401 (A52706)
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
New/Unused CFG Industrial NT20-CZ Mini Excavator (A57453)
New/Unused CFG...
PREVIEW DATES AND TIMES (A57453)
PREVIEW DATES AND...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
