Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #21
So, are we putting this angle iron on one plane, inner/outer, fore/aft? I'm thinking about making a 90 with it to catch one side and one fore or aft.
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #22
I put mine on the front and back and left the sides open to minimize clogging up.
I think I would do front and back because for one that is what I have seen and I think it will make it easier to align a board between the 2 channels parallel the outrigger as it lowers from the outside rather than trying to fight against the channels as they come down adjacent to the outriggers. Thinking ahead in case I'm in mud or soft pavement and need to increase contact with the ground.
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #24
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #25
I put mine on in a U pattern (leaving the inside edge or bottom edge of the raised stab open to allow dirt to fall out easily) to assist in keeping the tractor from moving to the side also. Sometimes I end up digging from the side of the tractor also and if you just put the angle (I used 1.25"x1/4" flatbar that I had in stock) on front and back then it has no grip on side to side slip.
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #27
That's exactly my thinking with the L pattern.
I don’t experience much slip sideways. Most of the work is straight off the back and when it’s not it’s probably not pulling very hard.
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #28
Yep. Really want to be careful digging at a 90 degree angle to the machine. It has it's most structural strength digging straight back.
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #29
A commercial TLB is well designed to be in the air. Remember a three legged milking stool is more stable than a four legged one. I would say that it is best to reduce stresses on most 3ph hoes by engaging stabalizers only enough to provide stability.
I was looking for a 3ph hoe for our JD 6200 years ago. When the dealer told me that people were ripping the rather heavy top link casting off the tractor, that was the end of that idea for me.
   / Backhoe operation - tractor tires off the ground, only the rear, only the front, NONE #30
I don't come close to that. But when digging stumps and swinging to 45 or so each side of the stump, I've pulled myself sideways a a bit.
2007 50FT 3 CAR HAULER TRAILER (A58018)
2007 50FT 3 CAR...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2018 John Deere 1653 (A56436)
2018 John Deere...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
2005 JOHN DEERE 317 SKID STEER (A52709)
2005 JOHN DEERE...
AG-FAB PULL TYPE SWEEPER (A58374)
AG-FAB PULL TYPE...
