Backhoe OK on a B7500?
   / Backhoe OK on a B7500? #1
Meadowdale
A fellow is selling his B7500 with Kubota backhoe. The hoe is not a subframe mounted model but uses the 3ph (I believe its the 4672) and I'm wondering if this will cause problems down the road. I've searched the older posts on TBN and it seems that a subframe would have been preferable.
Also, asking price is 12K. It's an '03 with about 350 hrs on it and it plus it has a MMM. Any thoughts on this asking price? Anything to look out for with the 7500? I'd love to get into a new B2320 TLB but I'm not sure that's going to happen anytime soon.
Thanks for any advice you all can give.
   / Backhoe OK on a B7500? #2
First of all hours are relative - http://www.tractorbynet.com/forums/...150221-b7610-hour-meter-tach-revolutions.html
I've run my 7610 for at least 40 hrs and only have put about 20 hrs on the meter.
The 3ph / 4672 - probably a 3ph with an extra strong toplink, that's how Kubota sold it.
yes it will cause problems, there will be backhoe envy, very similar to ***** envy, but if you got it use it!
And get a thumb!
Price - w/ FEL? If so a decent price. I got my '07 B7610 (245hrs), LA352 FEL, Bush Hog SBX 48 box blade, '07 Hudson HSE Deluxe trailer - 5 Ton 18' for 11.5K.
   / Backhoe OK on a B7500? #3
I'll let you know in a little while I'm just mounting a 3pth one on mine this week. Make sure you get the heavy duty top link part # 70050-540. There is also a frame stiffener bracket that should be added aswell part # b4681. I can take some pictures if that helps. The top link bracket should have 8 bolts in it. If you look under the tractor there should be an orange bracket on each side of the frame that runs from the front of the rear axle to the loader mounts. Kubota recommends both of these for the b4672 backhoe.
   / Backhoe OK on a B7500? #4
If it looks like this....
it will be fine. Absolutely NO Problems with mine...I love it!!!
   / Backhoe OK on a B7500? #5
Kubotas have not had a problem like some of the other companies with there backhoes. One company still has problems with their frame backhoes!
I think you will be fine.
Thanks guys for the info and reassurance. The TLB I BOUGHT (yeah I pulled the trigger last night) has the heavy duty top link and frame stiffiner that Taiser showed in his pics so I should be good to go. I got the price down a bit from the 12K he was asking and feel like everyone came away happy. Can't wait to get some seat time this weekend.
A thumb is definitely on the "to add" list.
   / Backhoe OK on a B7500? #7
Could you provide the part number and or a picture of the orange frame bracket. I bought an used 4672A and am trying to attach it to my B7510. I have called 3 local dealers and each says they don't know what I'm asking for. The B4681 is the top link mount.
Thank You
Fred
   / Backhoe OK on a B7500? #8
Its hard to get good pictures or the frame bracket because the mower deck is on I'll try. Basically it bolts to the sides of the rear axle and runs parallel to the frame and slightly lower and the bolts up to the front loader mounts. I was very surprised that my dealer knew what I was asking for. I'm sure someone here sent me a pdf with the part # and installation guide, I'll try to find it when I get home.
   / Backhoe OK on a B7500? #9
Here are a few pictures of the b4681 support frame kit. The last picture is of the upper link support, it differs from the original as it wraps over the top of the rear axle casting and has to extra bolts that come down from the top.
Hope this helps
  • scan0001.pdf
  • scan0002.pdf
   / Backhoe OK on a B7500? #10
Thanks for the frame stiffner info, Roy, (I have been looking for a used 4672 for my 05 7510....where did you find one? If you know of another, sure would be greatful.
jayutilitytractor............am I not supposed to give my e-mail address.....am so frustrated about not finding a BH, need all the help I can get but sure want to follow the rules....please let me know, Thanks.
jaysusy@sbcglobal.net
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A52577)
2015 VOLVO VNL...
