HI.....I've searched through everything in this forum that I can find trying to find a solution to my frontloader problem, and have tried and failed to resolve this.
This is a Kubota B2100 with LA301 frontloader. I had to replace a couple of the frontloader hoses due to leaks so replaced all four hoses coming out of the hydraulic block. Since then, the loader does not function. If I hold the lever down long enough, the loader will eventually jump a couple of inches and immediately stop until I go through the process again. Same with the tilt function of the bucket....if I hold the lever in position long enough I'll get a slight movement, but then it will stop, almost like it's built pressure up, but the pressure releases immediately after a little movement. I reseated all the quick connects and checked all other connections for leaks. The backhoe functions normally. Any suggestions on what to try next? Thanks.
