Backhoe Hydraulics good....Frontloader Hydraulics bad!!
/ Backhoe Hydraulics good....Frontloader Hydraulics bad!! #1
Shandaken
Kubota 2100
HI.....I've searched through everything in this forum that I can find trying to find a solution to my frontloader problem, and have tried and failed to resolve this.
This is a Kubota B2100 with LA301 frontloader. I had to replace a couple of the frontloader hoses due to leaks so replaced all four hoses coming out of the hydraulic block. Since then, the loader does not function. If I hold the lever down long enough, the loader will eventually jump a couple of inches and immediately stop until I go through the process again. Same with the tilt function of the bucket....if I hold the lever in position long enough I'll get a slight movement, but then it will stop, almost like it's built pressure up, but the pressure releases immediately after a little movement. I reseated all the quick connects and checked all other connections for leaks. The backhoe functions normally. Any suggestions on what to try next? Thanks.
/ Backhoe Hydraulics good....Frontloader Hydraulics bad!! #2
Shandaken:
:welcome: to TBN wish i could help but not to good on hydro but someone will come by and help.
/ Backhoe Hydraulics good....Frontloader Hydraulics bad!! #3
Maybe you have the hoses mixed up. Maybe the main lift and bucket tilt are cross connected. That's all I can think of.
/ Backhoe Hydraulics good....Frontloader Hydraulics bad!! #4
Bet you switched 2 hoses between the lift and tilt cylinders. The PO check valves will prevent anything from moving. Trace each hose to make sure they are both connected to the same set of cylinders.
/ Backhoe Hydraulics good....Frontloader Hydraulics bad!! #5
What he said and BigDeano said just before he did. Almost sure to be your problem. It's like sparkplug wires - if you don't know which point on the distributor fires which cylinder, change only one wire at a time.
Thanks all. Sounds reasonable even though I was VERY careful, but I still could have messed it up. I'll give it a try. Thanks again.
/ Backhoe Hydraulics good....Frontloader Hydraulics bad!! #7
If you changed out all hoses would you not have to bleed hydraulic fluid back into the lines?
As they are cylinders (not a thru feed motor) could there be a large air pocket trapped in the lines that you replaced.
If checking the lines are connected correctly does not fix your issue maybe try disconnecting each line individually at the cylinder and see if it pumps fluid out when you activate the valve. It may help to have a helper hold the hose end in a bucket to catch the hydro fluid.
(4) 275/65R20 GOOD YEAR WRANGLER TIRES (A63745)
(4) 275/65R20 GOOD...
JOHN DEERE 6' PIN ON BUCKET (A63745)
JOHN DEERE 6' PIN...
2011 Ford F350 Service Truck (A63116)
2011 Ford F350...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59910)
2016 FREIGHTLINER...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
Club Car Golf Cart (A64047)
Club Car Golf Cart...
