Backhoe Backhoe frame brackets
/ Backhoe frame brackets #1
OrangeJbird
NW WI
3320 w/300cx FEL
Do any of the 4*10 series brackets for backhoes fit the 3*20 series.
For example: a 447 from a 4210 to a 3320?
It would be nice for someone knowledgeable to come up with an interchange chart.
Do the 3*20 series use the same rear housing as the 4*10 series?
thanks for looking.
/ Backhoe frame brackets #2
The rear axle castings on the 3x20s look a lot different from the ones
on the 4310. I took some close-up photos of the rear of a 3120, and
one of my 4300s has a 4310 rear axle casting. The 3x10s have also
gone to an all-aluminum central rear gearbox. Big changes.
The definitive way to see if parts interchange is to compare part
numbers using JD parts or your parts book.
/ Backhoe frame brackets #3
The two brackets that were on the 4200/47 combo for example, were held on by eight bolts and required very little to install. I'm pretty sure the installation is now way beyond that to account for all the aluminum. I can't find the instructions where I saw that however...
The side plate kits for the 43/4400 - 43/4410 and the (31/33/35/3720) look nearly identical.
I originally asked about a 4210 didn't I.:ashamed:
So a 447/448/375/etc from a 43/4400-10 series will fit a 3320 with minimal mods?
/ Backhoe frame brackets #5
I'm probably thinking the subframe mounted ones. Either way, I don't think it will fit.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2020 John Deere 5090E (A64119)
2020 John Deere...
(2) UNUSED 11.2-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 11.2-24...
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
