Backhoe Backhoe for L3130
/ Backhoe for L3130 #1
jsduke
West Central Pa.
PT-425 (Former Kubota L3130 HST)
Does anyone have any in depth knowledge of the BL4690B kubota hoe? I've got an L3130 w/ 513 loader and am testing the backhoe waters for next year.
Seems I hamstrung myself a bit with this loader as the BH90 is only compatable with the 723 and up /forums/images/graemlins/frown.gif . The BH90 requires the mounting system of the 723, it's not just a weight issue. I wanted the 513 for it's lower profile and greater stability for work on hilly ground and tight wooded areas.
The Woods 7500/9000 hoes hang way out there on their subframes.
I could trade the loader for the 723 and then add the BH90, but I'll be kicking in 10K+.
I've heard the 4690 is a bit beefier in the mounting area than your run of the mill 3 pt. hoes. Don't know if that's the truth or not. How much does it overhang?
Thanks.
duke.
/ Backhoe for L3130 #2
duke
I have attached a drawing from the B4690 manual. Other than the top-link and seat all of the backhoe sets beyond the lower 3PH arms.
/ Backhoe for L3130 #3
duke
Attached is the spec sheet from the B4690 manual. Hope it helps with the information you are looking for.
I don't think the B4690 is as heavy duty as a BH90. I would look for a after market backhoe if you plan on doing any heavy work.
/ Backhoe for L3130 #4
Hi,
I have a BL4690B backhoe on my B2910. I like it, but...
The BH90 is one reason I fantasize about trading my B2910 for a L series tractor. I saw a L3130 [ or 3430?]with a Bh90 on it and that backhoe just looks so much sturdier.
The mounting system is better [four point subframe vs 3PH], the pivot system is better [cilinders vs chain setup], longer reach [if I remember correctly]...other things I have forgotten.
I said subframe but am not sure about that exactly. I remember brackets mounted to the frame that the BH90 attached to, but they were not as large as sub frame might be in some cases.
If I had an L series there is no way I would put a 4690 on it, unless I reallly needed the backhoe and could not find a way to afford more.
Each of our situations is different though... /forums/images/graemlins/smile.gif Not sure what I would do if I had to trade my loader in on a bigger one just so I could add the backhoe I wanted...
Jeep Metal Tailgate Metal Decorative Sign (A66738)
Jeep Metal...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2016 Ford Escape SUV. (A66738)
2016 Ford Escape...
CASE 721E WHEEL LOADER (A67714)
CASE 721E WHEEL...
