Backhoe for DK45SE tractor.
/ Backhoe for DK45SE tractor. #1
PaulP
I have a 2010 Bobcat CT450 cabbed tractor which is essentially, a re-badged Kioti DK45SE and I'm looking for a backhoe for it.
No luck from Bobcat or Woods when looking up attachment for "Bobcat" tractor but am thinking there is probably a backhoe for the Kioti branded tractor.
Anyone have any suggestions?
Thanks, Paul in VA
/ Backhoe for DK45SE tractor. #2
Is getting one of those Chinese mini excavators an option? Somewhere in the 2 Ton range probably.
It's a machine dedicated to digging, which a tractor is not and would free up the tractor to pull a dump trailer or something, plus it a more practical machine since you can turn 360 degrees and just move dirt from one side to another.
/ Backhoe for DK45SE tractor. #3
When I bought my dk45se a backhoe was an option. Have you checked with a Kioti dealer?
/ Backhoe for DK45SE tractor. #4
I can't say I've heard or seen anything that says these are a great option? If you are handy they are maybe a neat project, but from what I've seen you might need a better valve set so you can control it smoothly, they are made for someone 5'6", very slow moving. I do see a few these for sale with single digit hours locally as I think people try them and find they aren't very appealing.
/ Backhoe for DK45SE tractor. #5
Yes you need to spend $10K for a 3600 Lb Chinese Diesel Mini with 3000Lb digging force. I have one and a Kubota TLB - they compliment one another as the mini is good at digging, bad at moving very fast.
IMO, if you are doing serious digging regularly, get at least 3 Ton mini ex with 2 Spd drive - used they are 20-25K.
/ Backhoe for DK45SE tractor. #6
When I bought my Koiti DK40SE, I put a Woods BH-90X Groundbreaker backhoe on it. I would contact Woods to see if they make a subframe kit for your machine, or the kioti equivalent
725 Gal Poly Tank on Skid  (A62679)
725 Gal Poly Tank...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
1062 (A63291)
1062 (A63291)
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
