Backhoe for DK45SE tractor.
/ Backhoe for DK45SE tractor. #1
PaulP
Member
I have a 2010 Bobcat CT450 cabbed tractor which is essentially, a re-badged Kioti DK45SE and I'm looking for a backhoe for it.
No luck from Bobcat or Woods when looking up attachment for "Bobcat" tractor but am thinking there is probably a backhoe for the Kioti branded tractor.
Anyone have any suggestions?
Thanks, Paul in VA
/ Backhoe for DK45SE tractor. #2
Is getting one of those Chinese mini excavators an option? Somewhere in the 2 Ton range probably.
It's a machine dedicated to digging, which a tractor is not and would free up the tractor to pull a dump trailer or something, plus it a more practical machine since you can turn 360 degrees and just move dirt from one side to another.
/ Backhoe for DK45SE tractor. #3
When I bought my dk45se a backhoe was an option. Have you checked with a Kioti dealer?
/ Backhoe for DK45SE tractor. #4
I can't say I've heard or seen anything that says these are a great option? If you are handy they are maybe a neat project, but from what I've seen you might need a better valve set so you can control it smoothly, they are made for someone 5'6", very slow moving. I do see a few these for sale with single digit hours locally as I think people try them and find they aren't very appealing.
/ Backhoe for DK45SE tractor. #5
Yes you need to spend $10K for a 3600 Lb Chinese Diesel Mini with 3000Lb digging force. I have one and a Kubota TLB - they compliment one another as the mini is good at digging, bad at moving very fast.
IMO, if you are doing serious digging regularly, get at least 3 Ton mini ex with 2 Spd drive - used they are 20-25K.
/ Backhoe for DK45SE tractor. #6
When I bought my Koiti DK40SE, I put a Woods BH-90X Groundbreaker backhoe on it. I would contact Woods to see if they make a subframe kit for your machine, or the kioti equivalent
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
