Backhoe for DK45SE tractor.
/ Backhoe for DK45SE tractor. #1
PaulP
I have a 2010 Bobcat CT450 cabbed tractor which is essentially, a re-badged Kioti DK45SE and I'm looking for a backhoe for it.
No luck from Bobcat or Woods when looking up attachment for "Bobcat" tractor but am thinking there is probably a backhoe for the Kioti branded tractor.
Anyone have any suggestions?
Thanks, Paul in VA
/ Backhoe for DK45SE tractor. #2
Is getting one of those Chinese mini excavators an option? Somewhere in the 2 Ton range probably.
It's a machine dedicated to digging, which a tractor is not and would free up the tractor to pull a dump trailer or something, plus it a more practical machine since you can turn 360 degrees and just move dirt from one side to another.
/ Backhoe for DK45SE tractor. #3
When I bought my dk45se a backhoe was an option. Have you checked with a Kioti dealer?
/ Backhoe for DK45SE tractor. #4
I can't say I've heard or seen anything that says these are a great option? If you are handy they are maybe a neat project, but from what I've seen you might need a better valve set so you can control it smoothly, they are made for someone 5'6", very slow moving. I do see a few these for sale with single digit hours locally as I think people try them and find they aren't very appealing.
/ Backhoe for DK45SE tractor. #5
Yes you need to spend $10K for a 3600 Lb Chinese Diesel Mini with 3000Lb digging force. I have one and a Kubota TLB - they compliment one another as the mini is good at digging, bad at moving very fast.
IMO, if you are doing serious digging regularly, get at least 3 Ton mini ex with 2 Spd drive - used they are 20-25K.
/ Backhoe for DK45SE tractor. #6
When I bought my Koiti DK40SE, I put a Woods BH-90X Groundbreaker backhoe on it. I would contact Woods to see if they make a subframe kit for your machine, or the kioti equivalent
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2025 SDLanch SDLL30 Mini Stand-On Track Loader Skid Steer (A59228)
2025 SDLanch...
1986 Military MEP 0006A 60kW Towable Diesel Generator (A59228)
1986 Military MEP...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
