Backhoe Backhoe cylinder
/ Backhoe cylinder #1
birddog55
Well fellas I had a bad backhoe cylinder and I went to replace the seals and instead of just the seals the shaft itself was bad. the cylinder I am talking about is the cylinders that shift the boom left and right. The shaft broke were they drilled it so you could place a cotter pin to hold the nut that holds the plate inside the cylinder. I was wondering if you can just buy the shaft or do you think that I will have to buy a whole new cylinder?
/ Backhoe cylinder #2
Bring it to a hydraulic cylinder shop. They can make a new rod. It's no big deal to do. Almost always cheaper to have a new rod made than getting one from the dealer.
/ Backhoe cylinder #3
/ Backhoe cylinder #4
Or you might get lucky and someone on TBN may have one laying around their shop.
/ Backhoe cylinder
Thanks Tommy I'll call tommorow
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
UNUSED FUTURE D680 HYD PILE HAMMER (A65055)
UNUSED FUTURE D680...
Husky 5000Watt Portable Gasoline Generator (A64553)
Husky 5000Watt...
2004 Mack RD690S Tri-Axle Rolloff Truck (A64194)
2004 Mack RD690S...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64556)
2022 Chevrolet...
