Backhoe buckets!
/ Backhoe buckets! #1
countrybumpkin
Elite Member
Kioti, kubota
Any one have or know were to get plans to build your own buckets for backhoes. i bought a case hoe for my Kubota and am needing a small bucket to go along with the 18 inch that is on it.
/ Backhoe buckets! #2
What about making a copy of what you have just narrower? Get some cardboard and make a template.
/ Backhoe buckets!
Guess that would work, Sometimes just don't see the obvious. What size bucket are people using for a small one. I was thinking around a 6" for running eletric lines or drain pipes stuff like that.
/ Backhoe buckets! #4
I don't think you can get down in the trench with anything less than a 12" bucket. Plus I would think that a 6" bucket might be a bear to keep clean (more apt to plug with moist dirt). We use a 12" bucket for our digging needs and it seems to work well.
/ Backhoe buckets! #5
I have a 24" and 12" buckets. A 12" trench is workable but its fairly tight. A smaller bucket would be ok for shrubs etc.. where your not working in the hole/trench. You may not want to go smaller than 8" or 10" because the dirt has a tendancy to stick in a narrow bucket. Others could probably comment better on that aspect.
/ Backhoe buckets! #6
I've got a 9" bucket that is great for running drain lines and electrical conduit.
Greg
/ Backhoe buckets! #7
</font><font color="blue" class="small">( dirt has a tendancy to stick )</font>
I've seen some weld short length of chain in trench bucket for that problem.
/ Backhoe buckets! #8
</font><font color="blue" class="small">( </font><font color="blueclass=small">( dirt has a tendancy to stick )</font>
I've seen some weld short length of chain in trench bucket for that problem. )</font>
Could you clarify what length chain and where is it welded
/ Backhoe buckets! #9
I made several buckets for my BH. Some plate steel, cutting bar, 3/4" stock for the pivot point brackets, a sledgehammer and an old stump. (These last two are v-e-r-y helpful for putting that gentle little curve in the bottom of the pan.) I used what I had and could scrounge up.
The smallest was a 12" which I found great for laying pipes and cables. It was reinforced and sharpened on all edges for cutting through roots. I got the teeth from a local Bobcat dealer and pinned them onto my home-made tooth mounts.
I also made a 16" for normal dirt digging and a 24" for culvert installations. The wider, the shallower to prevent strain on the little hoe.
As I recall, the dealer wanted several hundred $$$ each but I had less than fifty bucks in them all. /forums/images/graemlins/grin.gif
Go for it!
/ Backhoe buckets! #11
I made a 13" bucket for my CADDigger 728 about 10 y ago. I followed their plans to bend and weld a piece of 1/4" plate to form the carcass. It worked well and the bucket was hefty. The buckets I have for my Praire Dog b/h use a thinner main carcass and formed (curved) wear strips made of plow steel for the edges and center. Both use commercially-available tooth holders and teeth.
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
John Deere 33 Manure Spreader (A66408)
John Deere 33...
(10) New CATERPILLAR Keys (A65579)
(10) New...
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
