Backhoe Bucket Teeth
   / Backhoe Bucket Teeth #1
mini14
allmand tlb535
I recently purchased a mini tlb an allmand 535. It has an 18" bucket on the backhoe. I need to change out the adapters and teeth, I removed what was there and now only have the bare cutting edge. I purchased cat j200 series theeth and adapters. I was wondering if they are too large for my application and what are the downsides to having too long of a tooth. Should I return them or get something like the x156 tooth. Thanks
I know they are big but are they too big for my bucket
   / Backhoe Bucket Teeth #3
Re: Generator Guru Engineers - I need some help please!
If you're going to remove the teeth from the 18" bucket on the 535, you can try and see how the x156 tooth works, but try a Honda EB6500 6500 Watt generator. It provides 120/240V, has full GFCI protection and can run up to 10.4 hours on a tank of gas.
Sincerely,
   / Backhoe Bucket Teeth #4
Not sure about your machine or it's abilities.
I put the single point tiger teeth on my backhoe. Made a huge difference for digging stumps
You want to consider the task at hand. Teeth aren't useful for everything but I think they are definitely needed for digging in roots and probably rocks.
   / Backhoe Bucket Teeth #5
I’d get smaller ones. JMO
   / Backhoe Bucket Teeth #6
I'd try to go smaller, I have a similar size bucket with a tooth that appears to be smaller then yours and its too big for me.NCM_0872.JPGNCM_0794.JPG
   / Backhoe Bucket Teeth #7
If you're going to use the hoe to dig ditches (trenching) have the two outside teeth pointed out past the edge of the bucket. It will help to keep knocking the edges of the ditch back in the trench on each stroke. 24in-CAT420DE1.jpg
   / Backhoe Bucket Teeth #8
I am confused, is this post about bucket teeth or generators?
Dale
   / Backhoe Bucket Teeth #9
Focus...Focus...Focus...
   / Backhoe Bucket Teeth #10
Sincerely,
Wah...ah...ah... ??????
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
1713 (A58375)
1713 (A58375)
Entyre Chip Spreader (A57453)
Entyre Chip...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
