Backhoe attachment, on a trailer. Making it a towable!
   / Backhoe attachment, on a trailer. Making it a towable! #21
This is more in line what I was thinking about. I still do not see more then $3000 in it, and other than the bucket curl cylinder being too short, it is a lot more capable then my Wallenstein Log Loader Backhoe because it can go deeper. The video also shows how two wheel towable machines can be moved on their own power.
Don't get me wrong, this is no Hitachi 1200, but for the money, and ease of build, I think its a very decent machine. I think if someone spent $3000 building it, they would be happy versus that of having a spade and pick axe.
unless you can swap the outriggers with the tires, it is not tow-able. there would be negative weight on the ball.
It also appears to be in desperate need of some reinforcement around the main "'elbow" pin
   / Backhoe attachment, on a trailer. Making it a towable! #22
   / Backhoe attachment, on a trailer. Making it a towable! #24
Thanks everyone for your inputs...
You, well, got mostly all my concern, questioning, written out and some answered!!!
Comes down to do the math and confirm which would be the best for me.
Another question, as for counter weight, or leveraging with the smaller weight of the unit.
I thought of using some land screw fix under the carriage. That should give me more holding power while remaining a lighter unit.
   / Backhoe attachment, on a trailer. Making it a towable! #26
Some of the plans call for filling the long tube under with lead to give it more operating weight.
   / Backhoe attachment, on a trailer. Making it a towable! #27
If I was building one, I wouldn't add weight to a plan's small tube. I would use a larger, thicker-walled tube.
Bruce
   / Backhoe attachment, on a trailer. Making it a towable! #28
Leave it hooked to the truck, that will be enough ballast.
   / Backhoe attachment, on a trailer. Making it a towable! #29
If you were sitting in one place that would be fine. It would be a royal pain to have to get off the hoe and reposition with the truck every time you needed to move. You are also limited to dig only where the truck could go.
   / Backhoe attachment, on a trailer. Making it a towable! #30
Have the outriggers sweep towards the back as far as practical and mount the engine and hydraulic resivoir on the tongue, should be plenty of counterweight as long as you match the hyd power to the weight.
I built a backhoe for my Kubota B and it's about right for the weight, I can still pick front off the ground if I catch a large root, if I had swept the outriggers to the rear a little it would have added a lot of stability. Wasn't practical though as it would have interfered with the boom.
It could have easily been attached to a trailer.
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
golf cart (A55787)
golf cart (A55787)
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2016 Troy-Bilt 21in Push Mower (A55973)
2016 Troy-Bilt...
Freightliner Fuel Truck (A56435)
Freightliner Fuel...
