Mowing Back up camera for brush hogging in tight spots
   / Back up camera for brush hogging in tight spots #23
Ive been using my gopro and ipad as temporary remote video monitoring for years. Backup camera for bumper hitches on everything, gooseneck is nearly impossible without getting out of truck several times because of crew cab and tool box in bed, watching clearance on speed bumps with my boat trailer or t top clearance under some tree limbs before I sold boat.... not good for any long term usage
   / Back up camera for brush hogging in tight spots #24
   / Back up camera for brush hogging in tight spots #25
I like your monitor mount. My right hand door is worthless for trying to use so that spot would be ideal.
Thanks. It works well. I can still use the door...mount is very solid
   / Back up camera for brush hogging in tight spots #26
I have a Ram mount in about the same spot for my phone. My right hand door is usable for access, just not ingress or egress. The go pedal & joystick are in the way. I could squeeze past them, but its risky. Very risky if the machine is running.
   / Back up camera for brush hogging in tight spots #27
Not a waterproof display but good for a cab tractor. I got this setup over Black Friday/Cyber Monday on Amazon (it was under $200 in that sale). It has two wireless cameras and a 7" display. I've already mounted the camera for the rear to use while snowblowing and I am planning to mount the second camera on the loader cross bar so I can easily see my front QA when hooking up attachments. The cameras only require a power connection so I am wiring into the parking lights so when I turn the parking lights on, the cameras will come on.
https://www.amazon.com/gp/product/B07BS2FYKD/ref=oh_aui_search_detailpage?ie=UTF8&psc=1&pldnSite=1
   / Back up camera for brush hogging in tight spots #28
I often wish tractors were made with seats that would swivel 90 degrees or more.
I really like some of the bi-directional European tractors I've seen. The whole cab rotates 180 degrees.
Bruce
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
2007 STERLING A9500 DAY CAB (A57880)
2007 STERLING...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2015 GMC 3500 HD 4x4 Crew Cab Pickup truck (A55973)
2015 GMC 3500 HD...
