Mowing Back up camera for brush hogging in tight spots
   / Back up camera for brush hogging in tight spots #11
   / Back up camera for brush hogging in tight spots #12
My previous experience is buried somewhere in A backup camera for $5!!!!!!!!!!! .
Basically a $120 outdoor rated camera & monitor on my open station L3200. Even with the smallish OEM hood on it was nowhere bright enough for me to use in moderate sun.
I keep having delusions I'll try again on my cabbed L4060, but it's just not that likely. I'd want something higher resolution than what's out there for a vehicle cam & brighter. Even then I never found my first bucket csm nearly as useful as I'd hoped.
   / Back up camera for brush hogging in tight spots #13
   / Back up camera for brush hogging in tight spots #14
Man this looks like the ticket... Great reviews
Looks very good for the price but as Fallon said, your screen brightness in the sunlight will be your bane. Likely you will be fabricating a large shade in attempt to get a decent view worth looking at.
   / Back up camera for brush hogging in tight spots #15
I have done it on my cabbed tractor.
No complaints after about 4 years now.
And all that 4 about $50 from an offshore site.
   / Back up camera for brush hogging in tight spots #16
Sounds like an excellent idea. My neighbor and his 34 foot "Luxo - bus" has one out back. Its on a powered gimbal - he normally looks straight back - like a rear view mirror. But it can also be gimballed down so he can see the trailer hitch as he backs up to connect his Jeep.
In the years - 28 - that I used a 3-point snow blower - no monitor, but I did get a rear view mirror.
BE ADVISED - there will be a definite learning curve here. Be overly cautious the first few times its used. The mind may not be tuned to views and movements of vehicles as they back up - as viewed on a monitor. You certainly do not need to damage or cause damage with that 3-point implement.
   / Back up camera for brush hogging in tight spots #17
Tried it on my little JD and took it right back off. It was in no way a substitute for looking back with your eyes. I wish it was because of the sore neck but alas it didn't work out for me.
My opinion is that unless you do a constant, repetitive, most of the time job needing it, it will not be satisfactory for most people. First, it is only practical for a cab tractor unless you have some quick disconnect way to bring the monitor indoors. Secondly, the rear view TV in both of our cars is a nice gadget but only marginal in value when push comes to shove. Third, I think you will find it a distraction which may actually cause you more trouble than doing without it. If you wanna play with gadgets (as I often do too), then have at it. Just don't expect too much.
BY the way, if I were going to get one I would look for wireless connections such that the monitor and the camera like each other with no wires between and no power connection to the tractor. Battery operated. Surely those exist and by magnet mounting them you could take it on and off at will and make other uses of it too.
   / Back up camera for brush hogging in tight spots #18
Pyle PLMRM72B Hydra Series Marine Grade Water Resistant 7-Inch LCD Wide-Screen Monitor with Anti-Glare Shield and Universal Stand (Black) (Discontinued by Manufacturer) https://www.amazon.com/dp/B00DHOEPQG/ref=cm_sw_r_cp_apa_i_jpTcCbFMEXRJS obviously now discontinued was mine I think & around $120. Not sure how actually "marine" rated it was, but it survived 2 years on my open station L3200. Granted I did keep it in the barn though so it didnt get a lot if weather.
I'd be surprised if there weren't more like that around under $200 if you looked hard enough.
Reasons 2 & 3 are kind of why I haven't bothered on my new machine.
I disagree on wireless. I prefer wired for everything I can. I'm an IT engineer, HAM & dabble in ethical RF hacking. Troubleshooting anything wireless is a lot more painful & much more failure prone than a wired connection. Add in batteries to go dead & it's much worse. Maybe on the end of a telehandler or crane where cable management becomes unmanageable, but it's not that hard to run wires down a loader or up ROPS or a cab.
2023 John Deere XUV 825M S4 (A56469)
2023 John Deere...
Informational Lot - Financing (A56435)
Informational Lot...
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
2017 Kubota M7-151 Premium MFWD Tractor (A55315)
2017 Kubota M7-151...
