eBay/Craigslist Back hoe question
/ Back hoe question
I am not sure if there is a regen,,,,but it doesn't dump straight into the reservoir, it is some how intertwined with the 3 pt which, that's why I was blowing apart the return filters
/ Back hoe question #42
Did we know that before? Okay, the return MUST go directly back to the reservoir.
/ Back hoe question #43
Did you ever get the filter thing fixed?
The fluid should not go through the cannister low pressure filter and then to the 3pt. If your BH needs a filter, they make a high pressure inline filter.
All the fluid in the tractor is filtered, so any fluid going to the BH is filtered.
If you don't have a PB port on the BH valve, then you should not put a return line filter in the BH circuit, unless the TANK port is going directly to tank. .
This is a high pressure filter.
Surplus Center - SAE 8 12 GPM IN-LINE HIGH PRESSURE FILTER
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A67148)
2008 FORD E- 350...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A67147)
2005...
2016 Ford F-450 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2016 Ford F-450...
