eBay/Craigslist Back hoe question
/ Back hoe question
I am not sure if there is a regen,,,,but it doesn't dump straight into the reservoir, it is some how intertwined with the 3 pt which, that's why I was blowing apart the return filters
/ Back hoe question #42
Did we know that before? Okay, the return MUST go directly back to the reservoir.
/ Back hoe question #43
Did you ever get the filter thing fixed?
The fluid should not go through the cannister low pressure filter and then to the 3pt. If your BH needs a filter, they make a high pressure inline filter.
All the fluid in the tractor is filtered, so any fluid going to the BH is filtered.
If you don't have a PB port on the BH valve, then you should not put a return line filter in the BH circuit, unless the TANK port is going directly to tank. .
This is a high pressure filter.
Surplus Center - SAE 8 12 GPM IN-LINE HIGH PRESSURE FILTER
2020 FREIGHTLINER M2 4X2 S/A 26FT CDL REQUIRED CURTAINSIDE BOX TRUCK (A67148)
2020 FREIGHTLINER...
2020 Bobcat S450 Compact Wheel Loader Skid Steer (A64553)
2020 Bobcat S450...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
2012 Mitsubishi Fuso Box Truck (A64556)
2012 Mitsubishi...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
