Back Hoe Hoses rubbing
/ Back Hoe Hoses rubbing #1
Mark_G
Va
Kioti CK30 Synchro Shuttle
The hoses on my back hoe are rubbing where they go in and out of the arms etc. I was thinking of cutting pieces of pvc pipe the length of the metal edges, then cut a vertical slit and epoxy it over the edges so it is a smooth slick surface foe them to rub on. The nylon sock has worn away in several areas.
Any other thoughts or ideas?
Thanks
Mark
/ Back Hoe Hoses rubbing #2
When this has happen to me, I have taken a piece of automotive heater hose, slit it lengthwise and used tie-wraps to hold it on the hose being protected.
This transfers the wear to the heater hose, which can be replaced as needed.
Using PVC pipe the way you describe will keep the wear on the hydraulic hose, although it may reduce the rate.
Heater hose is available in many diameters.
/ Back Hoe Hoses rubbing #3
I was looking at a new Case dozer working across the road with a 6 way blade and the hoses had some kind of steel coiled protection around the hoses at risk. The split heater hose sounds the way to go to me too.
Thanks for the thought. Heater hose it is.
What type of glue do you suggest?
Thank you,
Mark
/ Back Hoe Hoses rubbing #8
Do you guys mind posting some picture of the backhoe hoses? Some of hoses on my new backhoe are starting to leak, very minor at this time. I wondering if the way some of the hose are tie-wrap down is causing stress at the fittings. My backhoe is a kioti KB2485.
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
New/Unused 20 Ton Hydraulic Jack (A65583)
New/Unused 20 Ton...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
