Back hoe for 755
/ Back hoe for 755 #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
A buddy was asking about what options he might have for putting a back hoe on a 755. I told him I did not think anyone made anything for the 55 series but I would raise the question on TBN.
Any ideas? Does anyone make a unit that would drive off the PTO?
/ Back hoe for 755 #2
There's a number of aftermarket backhoes....try Woods Equipment.
As far as a Deere model, I'm pretty sure the 755 uses the #7 backhoe.
I strongly suggest he look for one that uses a subframe and not just a 3PH mount.
/ Back hoe for 755 #3
I also think the 755 utilized the #7 since the 855 & 955 both do. I doubt you'll find one new from a dealer, at least not with the proper mounting components. It's a no brainer to want the sub-frame type. Too much strain in directions the 3pt mounts aren't designed for. The 755 had a power-beyond option available. I think you could construct it almost entirely from factory parts since the complete kit is NLA. The PB is good for other uses as well, I drive my wood splitter with it.
/ Back hoe for 755 #4
I believe the PB kit is still available. It's part number begins with a "B" which means it is a "whole goods" item and will not show up on jd parts. You have to contact a dealer and have them get it for you.
/ Back hoe for 755 #5
Did not know that. Still, even if not you could order the parts needed or even build your own though I like the finished look of the OEM product better.
/ Back hoe for 755 #6
I've done it both ways on the x55's... built my own and bought the Deere parts. Last time I inquired was two years ago and the kit was still available then. I've also gone a third route... buying some of the individual parts from Deere and sourcing some of them elsewhere. That effort resulted in an OEM appearance at a substantial savings.
/ Back hoe for 755 #8
I recently bought the PB Kit for my JD 790, it is still available.
The kits are specific for a tractor model...what works on a 790 probably won't work on a 755.
However, one does see kits such as this on eBay occasionally...worth a look.
/ Back hoe for 755 #9
That's actually where I got mine, eBay. Bought it years ago and put it on the shelf. Wasn't until I had troubles with my other tractor and couldn't operate the log splitter that I finally installed it. Works better too.
/ Back hoe for 755
Thx for responses guys. My pal has decided that giveen his likely use, an occasional mini-hoe rental makes more sense.
/ Back hoe for 755 #11
That frequently seems the case. There is something to be said for having the machine whenever you need it, but then if you only use it once or twice a year it's hard to justify. Renting a Bobcat 337 for a week costs me around $800. That's what I choose to do over buying a bigger machine.
EZ Trail 3400 (A63688)
Peanut Wagon (A64127)
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
2022 EZ-GO ELITE...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
