Back hoe for 755
/ Back hoe for 755 #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
A buddy was asking about what options he might have for putting a back hoe on a 755. I told him I did not think anyone made anything for the 55 series but I would raise the question on TBN.
Any ideas? Does anyone make a unit that would drive off the PTO?
/ Back hoe for 755 #2
There's a number of aftermarket backhoes....try Woods Equipment.
As far as a Deere model, I'm pretty sure the 755 uses the #7 backhoe.
I strongly suggest he look for one that uses a subframe and not just a 3PH mount.
/ Back hoe for 755 #3
I also think the 755 utilized the #7 since the 855 & 955 both do. I doubt you'll find one new from a dealer, at least not with the proper mounting components. It's a no brainer to want the sub-frame type. Too much strain in directions the 3pt mounts aren't designed for. The 755 had a power-beyond option available. I think you could construct it almost entirely from factory parts since the complete kit is NLA. The PB is good for other uses as well, I drive my wood splitter with it.
/ Back hoe for 755 #4
I believe the PB kit is still available. It's part number begins with a "B" which means it is a "whole goods" item and will not show up on jd parts. You have to contact a dealer and have them get it for you.
/ Back hoe for 755 #5
Did not know that. Still, even if not you could order the parts needed or even build your own though I like the finished look of the OEM product better.
/ Back hoe for 755 #6
I've done it both ways on the x55's... built my own and bought the Deere parts. Last time I inquired was two years ago and the kit was still available then. I've also gone a third route... buying some of the individual parts from Deere and sourcing some of them elsewhere. That effort resulted in an OEM appearance at a substantial savings.
/ Back hoe for 755 #8
I recently bought the PB Kit for my JD 790, it is still available.
The kits are specific for a tractor model...what works on a 790 probably won't work on a 755.
However, one does see kits such as this on eBay occasionally...worth a look.
/ Back hoe for 755 #9
That's actually where I got mine, eBay. Bought it years ago and put it on the shelf. Wasn't until I had troubles with my other tractor and couldn't operate the log splitter that I finally installed it. Works better too.
/ Back hoe for 755
Thx for responses guys. My pal has decided that giveen his likely use, an occasional mini-hoe rental makes more sense.
/ Back hoe for 755 #11
That frequently seems the case. There is something to be said for having the machine whenever you need it, but then if you only use it once or twice a year it's hard to justify. Renting a Bobcat 337 for a week costs me around $800. That's what I choose to do over buying a bigger machine.
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2021 Peterbilt 579 (A64127)
2021 Peterbilt 579...
Front Tank Bracket (A64127)
Front Tank Bracket...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
