Back dragging with bucket
/ Back dragging with bucket #1
zpilot
Conn.
CK2610
I have a CK2610, when I try to back drag top soil with the bucket the bucket no matter the angle will fold back quite a bit making spreading top soil not very easy. Any suggestions? TIA.
No it is not.
/ Back dragging with bucket #4
Are you talking about the bucket curl function?
Yes.
/ Back dragging with bucket #6
"Floppy Bucket Syndrome". Caused by the volumetric difference between the rod side and piston side of the cylinder. The Low Volume side (Rod End) empties fluid faster that the high volume side causing cavitation of the hydraulic fluid.
Simple fix, install a Flow Restrictor in the Low Volume side at the Loader Quick Coupler (White Hose). This will slow the bucket movement down, but will also act to keep both sides of the cylinder balanced and eliminate most of the "Sloppy Bucket" effect.
Hope this helps
/ Back dragging with bucket #7
Once you set the bucket on the ground at the angle you want, hold over on the loader joystick a bit longer till you get tension on the bucket (see/feel the bucket start to angle slightly more) Then backdrag.
Thanks will try it tomorrow.
/ Back dragging with bucket #9
Yes, this is what I have to do with my CX as well, also I notice if I run too low of RPM it will do it more often. Also, the flow restrictor is a great idea.
/ Back dragging with bucket #10
Tractor buckets are not exactly the best tool for this task.. rear blade, box blade or land plane would be a better choice.
/ Back dragging with bucket #13
Old and slow is correct, use float mode to protect your tilt cylinders. Just keep the bucket flat to ground to pull material with the heel of bucket, to release material just move your joystick to the right which will raise the heel and allow material to flow under your bucket. With a little practice it’s easy.
/ Back dragging with bucket #15
...Forgot to add if you want the method of using the back, heel of the bucket to work even better (in float mode) Fill the bucket with dirt (or rocks) to give it more weight as you back drag it.
You will not flatten it in one drag, you have to go over the area multiple times. Even then, a box blade (or rear blade) might be needed.
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
(5) 10 X 20 STEEL MATS (A64276)
(5) 10 X 20 STEEL...
