Grading Back blade setting
/ Back blade setting #1
Joeinindy
Jamestown, Indiana
Kubota L3410HST 2000
When using the rear blade just how low do most of you set it? I plowed snow for the first time last night and most of the time I had it all the way down but it sounds like it's scraping the heck out of the blade. I'm new to all of this so maybe that's normal.
/ Back blade setting #2
I set mine up while its in the garage and level,then set it so its just off the floor by a 1/2inch or so.My drive is gravel so I drive in reverse,keeping the backblade in the normal position so it doesn't dig into the stones and drop them all over the yard.If your blade has a replaceable edge I wouldn't worry too much,thats what its there for. my2cents,Tom
/ Back blade setting #3
Joe,
Sounds normal when the ground is froze,and if you have shoes on your lblade you might adjust them a half inch or to keep the blade from touching the ground while your blade floats.
Thomas..NH /w3tcompact/icons/wink.gif
/ Back blade setting #4
Last year was my first year with the blade on my gravel drive, and I spent the winter doing a real bang-up job of getting every last flake of snow off down to clean ground - had the best looking driveway in the neigborhood. I was happy as a pig in $hit until...I saw all of my driveway plowed onto the lawn in the spring! I now set my blade about 1 inch above the ground, and live with the thin layer of snow I leave benind. This is easy to do with position control, woud be much harder without it.
/ Back blade setting #5
Paul,
The things we find after the snow removeal season comes to an end, /w3tcompact/icons/shocked.gifbut with a hand rake and TLC its good as new. /w3tcompact/icons/smile.gif
/ Back blade setting #6
Everyone experiences scarping and banging while plowing with the blade on the ground as I agree with Blu21 that the replaceable edge is made to be replaced. With frozen ground I cant imagine you have hat serious of problem with the stones. Try turning the blade around so the front now faces backwards and drive forwards. I hear driving backwards while pushing the blade puts additional stress on the 3pt. hitch. Happy Plowing! /w3tcompact/icons/smile.gif
The Ben from MA /w3tcompact/icons/cool.gif
/ Back blade setting #7
I have skid shoes which I set about 1/2 inch when on the blacktop and higher when I go onto the grass or gravel. I drive forwards and "windrow" the snow. I can't see driving backwards since I only have two reverse gears. One would be too fast and the other too slow and I don't want to strain my neck all the time anyway. I could go through a foot of snow driving forwards easily so can't see the big advantahe in driving backwards. (Glad I have skid shoes though, money well spent)
2014 Blu-Jet AT3000 Applicator (A66285)
2014 Blu-Jet...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
