b8200 hst no power
/ b8200 hst no power #21
Someone has to be willing to tell me how to go about this
/ b8200 hst no power #22
Are you wanting to split the tractor and rebuild the hydrostat? Or are you trying to do the testing? I'd say these aren't really amateur jobs. Splitting the tractor isn't that tough but rebuilding the hydrostat takes a bit more skill, plus it's a couple day job even for a professional mechanic.
As far as testing the pressures most hydrostats need some specialized fittings to hook the gauges to and you'll need the manual to walk you through it.
Brian
/ b8200 hst no power #23
Brain this is what I was thinking of trying to repair ?? It what the other guy had posted
I'm broke so maybe reaching for straws??
You are right it, is the secondary (drive pump) in the hst... dealer is going to try fix it .... the drive pump will not hold pressure, and the warm it gets the quicker it losses pressure... Thanks for the input.....
/ b8200 hst no power #24
Well the two rotating groups (pump and motor) in the hydrostat are about $500 each plus the two wear plates at probably $100 each. Sometimes the brass piston shoes and wear plates can be lapped with lapping compound on a flat plate or piece of glass. Your results may vary.
How do you know this is even the problem? Using "some guy on the internet 13 years ago had the same problem so that must be it" is a poor diagnostic tool.
Brian
/ b8200 hst no power #25
Brian
Thanks again
Let me explain, I asked after doing the search everything he stated is my problem
I would not do anything until I got it diagnosed by the dealer
I was asking about the fix, if it in fact did come out to,be,
Then it that point I would be able to decide if I should bring it home, or let the shop Do it
I maybe should have started a new thread
This is the first tractor I've had bought at yoder Frey auction
I changed fluids and cleaner Air filter I haven't pulled the fuel filter but I will in the next day or so
When I got it home the hydro oil was mixed with water I found the shifter boot was split
I have changed the fluid twice, after not liking the looks of the first change and a couple hours of use
/ b8200 hst no power #26
Have you cleaned or replaced the suction screen. The water in the oil gums them up pretty well.
Brian
/ b8200 hst no power #27
I have cleaned the only screen I know of
It is a large bolt that is on the right side of the tractor
If you where sitting on it ,it's rt and in behind your right foot
It is a very fine stainless mesh
/ b8200 hst no power #28
Do you have any other thoughts on what
I should do or try before I take it to the shop
Tommyt
/ b8200 hst no power #29
Does it have the problem in forward and reverse? Is the clutch properly adjusted? Is the clutch slipping?
Other than that all the test of the checks need the test fittings.
Brian
/ b8200 hst no power #30
It is very slow in both forward and reverse
Reverse is much stronger that forward
In forward after its warm it will just stop going forward
If there is as litter as a 2" change in terrain
I than have to put it in low #1 all other gears with will just
Not move
To get it in Shed there is a 2or 3 inch step up only in low low
/ b8200 hst no power #31
From the symptoms (water in the trans oil) it sounds like the tractor was auctioned because somebody knew it wasn't right when warmed up.
Brian's comments are all right on the money - check every other possible external cause like clutch, suction strainer, fluid level, etc, but hydrostatic drives are in a class by themselves and need a specialist. Most dealers do not service HST units. They follow factory guidance and replace them whole. If you take yours to a dealer expecting them to know how to fix it, you may get a call saying it's shot and the cheapest option is a new one - the tractor is already apart so cost is mounting even if they don't resolve it.
If it's a problem external to the HST then fine, but otherwise a solution might be to locate a decent used one (with clean fluid) and swap it out yourself.
BTW - for pressure testing the port threads are likely BSP (British straight threads). Adapters here.
2018 Bobcat MT55 (A64126)
2018 Bobcat MT55...
Kubota M125X (A60462)
2023 Mercury Verado 350HP Outboard Boat Motor (A61574)
2023 Mercury...
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
2022 John Deere 5055E (A62177)
2022 John Deere...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
