b7800
/ b7800 #1
rohdy
Farwell,MI
Kubota B7800
b7800 all of a sudden quit and won't start again. It keeps blowing the 30 amp fuse to the fuel solenoid before I can even get the fuse in all the way. It doesn't matter whether the solenoid is plugged in or not. Anyone know what's up?
/ b7800 #2
Sounds like a direct short to ground somewhere. Take the power supply off of the solenoid and see if the short goes away. You can also jump power to the solenoid to make sure the engine will start as well.
Good luck! :thumbsup:
/ b7800 #3
Yes I agree, direct short to ground. Trace wires to see if insulation on any supply wires have worn off and is touching metal which will go to ground. Start at battery and work towards the switch. keep use posted with results, good luck you'll find it if you take the time.
Devildog
/ b7800
b7800 all of a sudden quit and won't start again. It keeps blowing the 30 amp fuse to the fuel solenoid before I can even get the fuse in all the way. It doesn't matter whether the solenoid is plugged in or not. Anyone know what's up?[/QUOTE After checking everything out it ended up being a dust and dirt build up in the fuse box. I blew it out and stuck a new fuse in and it fired right up. Thanks everyone for the input.
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2007 Nissan Frontier SE Crew Cab Pickup Truck (A59230)
2007 Nissan...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
