B7800 with exhaust stack, and muffler removed
   / B7800 with exhaust stack, and muffler removed
I grew up in mid-Michigan on a farm in the 50's and 60's. You could always tell the farmers that had Farmall M's...they were the ones with hearing aids in both ears.
Thats OK cause I am deaf in one ear already, actually it sounds great, originally I went straight pipe and it was to loud, NOW IT ACTUALLY SOUNDS LIKE A TRACTOR NOT A LAWN MOWER, improved power and better economy as well, would do it all over on the next tractor only I would do it sooner,
   / B7800 with exhaust stack, and muffler removed #22
Great job! What do we call your kubota now? Kubota Hog.......
Actually I call it "MY TRACTOR", cause if I would have built it I would have built it MY WAY. This thing is now so much more tractor than I started with, do not get me wrong it was a good tractor to start with, but that is all, a good one to start with and start improving.......:thumbsup:
View attachment 365408View attachment 365409
How does that motorcycle muffler sound? I had an IH Cub muffler on mine for a while and it was too loud, then I found an oval muffler that fit 97 Civic and sounds much quieter. Good idea on the flex joint, looks just like the one I got, just haven't installed it yet.
Oh yea, we need to know about that breather too, have you done a thread on that?
Breather thread: http://www.tractorbynet.com/forums/customization/305508-modified-air-intake-air-filter.html
   / B7800 with exhaust stack, and muffler removed #25
I also have a 7800, how much more power do you think you got. Less fuel would be great too.
It does not seem to bog down as much when you go into a pile of dirt with the bucket, this is a hard one to answer, but it is a noticeable difference. If I were to buy another Kubota tomorrow I would do the exhaust and air filter modification right a away, I feel they are well worth it. Also something to consider is taking all the heat from the muffler out from under the hood.... Check the thread on the breather http://www.tractorbynet.com/forums/customization/305508-modified-air-intake-air-filter.html...
With the exhaust mod w/harley muffler and air filter mod w/precleaner I did an all day job for a neighbor (laying cold asphalt driveway) I ran it steady for 10 hours and used exactly 5 gallons of diesel. 2 hours per gallon seems pretty good to me.... The tractor runs fine with the mods and does seem to have gained quite a bit in the horsepower department.
   / B7800 with exhaust stack, and muffler removed #28
I forgot about this thread... started at the first page, was at the end of my post (#6) before I realized it was me writing it!
Good to hear the results, the warranty has expired on my tractor, so now I'm all for modifications! Better fuel economy and a tad more power would be nice... I wear ear plugs no matter what, so it might be straight pipe!
Groundhog RH14G Vibratory Articulated Tandem Smooth Drum Roller (A55851)
Groundhog RH14G...
2024 Schulte 5026 Batwing Rotary Cutter (A55315)
2024 Schulte 5026...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2014 Electric Cart (A53424)
2014 Electric Cart...
UNUSED SDLANCH SDLD 25 HYD DUMP BUGGY (A57192)
UNUSED SDLANCH...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
